Flat leisure batterys (1 Viewer)
big dave
38
8
earlswood solihull
rv
9 years
Arrived in Portugal hooked up to mains keeps tripping Sargent 380 leisure circuit
Both batteries pancaked flat so checked all fuses ok. Twin batterys in series so disconnected one trying to charge it but not very successful . Can a battery be u/s
in such a short time it's only 12 months old. I do not have smart charger only a
normal charger doesn't seem to want to play ball booked in with local repair guy
on Wednesday is there an internal fuse in the Sargent 380 unit.
Jul 13, 2008
3,737
3,802
Low profile
How are your batteries flat, don't they charge while driving?
Mar 23, 2012
9,524
31,948
sleights
c class
Won't 2 in series give you 24v sounds wrong to me?
TerryL
6,171
8,173
North East
Low Profile
At first a bit concerned about the batteries being in series - but then noticed you're an RV so presumably it's a 24 volts system. Can't help much but I wouldn't have thought a 24v charger would do a 12v battery much good. And yes, it has been known for batteries to "die" after 12 months, usually because they've been mistreated, been left fully discharged etc. Again I'm no expert but I should think a competent auto electrician doing a few checks will be able to sort it out for you. Good luck.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Sargent 380? are you sure of the number
andy63
4,672
15,017
south shields
None
since 1990
When you say keeps tripping???do you mean the mains supply keeps tripping?? Ie earth trip or overload ie fuse /breaker..Just don't understand the bit about the leisure circuit and sarent. Sorry if that's a dumb question.
Andy.
Techno
Jul 28, 2010
15,475
20,756
May 2010
So a 12 volt system which means batteries are in parallel.
For any diagnostics you simply need a voltmeter or you will get nowhere
Techno
Jul 28, 2010
15,475
20,756
May 2010
Start by seperating the batteries and measure the voltage of each, they should be the same. Any significant difference will show one is or has failed
It's also possible that the charger fuse has blown if it has been trying to charge a knackered battery
