Flat Battery!
Discussion in 'Motorhome Chat' started by StitchUp, Mar 31, 2013.
  1. StitchUp
    StitchUp Funster
    Mar 12, 2012
    883
    953
    Bridgend, South Wales
    Evening all :)
    Went out to potter about on the MH and discovered the battery was flat :Sad: - the engine battery. This happened once before and I just about managed to get jumper leads connected to get it started. I say, 'just about' because the battery's positive terminal isn't that accessible!
    Today, I just couldn't get a strong connection to allow enough current to flow to start the engine, it's freezing cold so I've put it off until tomorrow.
    When I took a good look at the battery I discovered it's not as conventional as I expected. Here's a couple of pics:
    [​IMG]
    The pos & neg terminals appear to be diagonally opposite one another - is this right?
    [​IMG]
    I can't make out what type of connection the positive terminal is and being beneath the bodywork, it was easier to get a picture :) How would I disconnect the battery if I needed to fit a replacement?
    Can anyone enlighten me?
    john
  2. francour
    francour Read Only Funster
    Mar 13, 2012
    94
    13
    Pontefract
    battery
    Its the fat red one undo the two black clips and its going round to the right ok .:thumb:
  3. Daveo2006
    Daveo2006 Read Only Funster
    Jan 25, 2013
    1,168
    987
    kent
    I had a flat battery on van once and it wouldnt turn over so used the 12v socket inside with my jump pack.Left it plugged in overnight and bingo,Is it maintenance free or maybe cells need topping up.
  4. simbadog
    simbadog Funster
    Sep 12, 2012
    1,298
    2,186
    Wengen
    Looks a bit like the negative terminal is a bit corroded? Might be worth unbolting the cleaning them up anyway.
    Just check that disconnecting power doesn't upset any engine management systems if you have any, you also might lose the radio & have to re code it.
  5. dshague
    dshague Funster
    Aug 22, 2007
    916
    187
    sth yorks
    if you do need a new battery go to somewhere that offers free fitting and let them have the hassle :Eeek:
    • Like Like x 2
  6. StitchUp
    StitchUp Funster
    Mar 12, 2012
    883
    953
    That was such a good idea I braved the elements and took my jump pack to the MH only to discover the power to the cigarette socket is disconnected when the ignition is off :( I tried putting the pack under the bonnet but the cables wouldn't reach the terminals and now I'm frozen :)
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,952
    17,626
    YO11 2BD
    get your jumper lead clamp across the two larger nuts towards the front of the metal plate.
    doesnt really matter where the connection is made as its all live.
  8. steles
    steles Read Only Funster
    Sep 2, 2007
    240
    61
    Kent
    Assume its x 250 cab, jump start positive connection in engine compartment negative is stud all shown in fiat handbook
    Steles
  9. pappajohn
    Aug 26, 2007
    29,952
    17,626
    YO11 2BD
    did wonder about that but no experience of the X250
  10. steles
    Sep 2, 2007
    240
    61
    Kent
    Not too sure now looked at pics
    Steles
  11. StitchUp
    StitchUp Funster
    Mar 12, 2012
    883
    953
    Thanks for this. I was wondering whether there'd be some more convenient way to connect but being 55 plate (2005), I wasn't sure.
    It's a Burstner 748 on a Fiat Ducato 2.8 diesel - I don't have the manual to hand so any clues?? I'd go out and connect my pack and leave it overnight :Smile:
  12. Daveo2006
    Jan 25, 2013
    1,168
    987
    kent
    I will try and scan page for you,not sure this will work out.
  13. steles
    Sep 2, 2007
    240
    61
    Kent
    Sorry should have looked at pics, not x 250 i guess as others say any good connection on positive will do. Can you not put on hookup for a couple of hours.
  14. Daveo2006
    Jan 25, 2013
    1,168
    987
    kent
    Ducato jump start.
  15. StitchUp
    StitchUp Funster
    Mar 12, 2012
    883
    953
    I'll sort it tomorrow when it's a little warmer :Smile:. Regrettably it's just a little to far for me to use an extension lead and put it on charge overnight.
    I'll probably make up some better way to connect to the positive terminal, makes life easier in the future.
  16. Daveo2006
    Jan 25, 2013
    1,168
    987
    kent
    This is no good:Doh: I can charge my battery on hook up yes, have you the option on control panel?
  17. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,143
    3,567
    walthamstow east london
    is there a jump lead connection point on the right of the engine bay usuall about 4/5 inches long red plastic cover which you flip up to exspose a bar below for connecting the live jump lead to the negative goes to any part of the engine theres normally a lifting ring at the front which is ideal
    im only working on my van conversion it may get removed during conversion as your batteries are under the bonnet rather than underfloor as mine are
  18. Daveo2006
    Jan 25, 2013
    1,168
    987
    kent
    mines still in place ,tried to post picture but my computing skills are not to clever.:Doh:
  19. StitchUp
    StitchUp Funster
    Mar 12, 2012
    883
    953
    Lifting ring is easily accessible but I couldn't find the 'HOT' connection post.
    [​IMG]
  20. Daveo2006
    Jan 25, 2013
    1,168
    987
    kent
    Different to mine,it is to the right in the centre with a stud on front right for negative
