Flat battery
Discussion in 'Tech/Mech General' started by Jim, Nov 3, 2007.
  1. Jim
    Jim Ringleader
    Jul 19, 2007
    26,120
    77,208
    Sutton on Sea
    Had to use my emergency start today, this is a switch i have that can pull the leisure batteries into the vehicle starting circuit. Seems that in 3 weeks of inactivity something has drained the vehicle battery, it was completely dead.
    My leisure batteries are kept topped up by two massive solar panels on my roof, it seems that even in mushroom growing Wales there is enough light to keep my leisures in tip top charge.
    How can I rig it so that my solar panels will drip a bit of juice into my vehicle battery as well?
  2. scotjimland
    Jul 25, 2007
    28,936
    25,589
  3. olley
    olley Funster
    Jul 29, 2007
    3,746
    2,188
    Ipswich
    Hi jim Battery master about £70, eddievanbitz flogs them. Or the cheap way a suitable wire between the positive terminals with a 20amp fuse in it. Just remember to pull the fuse before you start up.
    Olley
  4. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Yes you could, but to be on the safe side I would rather fit the Battery Master.. at £44.50 ..
  5. keith
    keith Funster
    Aug 25, 2007
    3,277
    1,652
    Ecclefechan
    Jim
    I believe Lidl have a device that I bought in Spain last winter currently for sale, not sure when though.
    It is a lead with a cig light plug at each end and a control box that lets you know whats going on. A lot cheaper than a battery master & I used it all the time I had my RV because the batteries seem to be independatly wired, except when driving.
    This solved the same problem for me & kept my battery charged for 6 weeks. :BigGrin:
    Keith
  6. keith
    keith Funster
    Aug 25, 2007
    3,277
    1,652
    Ecclefechan
  7. Diabalo
    Diabalo Funster
    Oct 14, 2007
    1,978
    384
    Rochester
    It would only work if your cig lighter is live with the ignition off surly
  8. keith
    keith Funster
    Aug 25, 2007
    3,277
    1,652
    Ecclefechan
    Diabalo
    Yes you are right if it was a European, but I think you will find RV's sockets are live when ignition is switched off, at least mine were.:thumb:
    Keith
  9. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
  10. Bryan
    Bryan Read Only Funster
    Jul 19, 2007
    2,096
    342
    Jim,
    Have you read the manual that came with your new solar panel regulator thingy?
    My regulator thingy charges bank 1 (leisure) and when full, switches to bank 2, Engine/Chassis).
    You may find that yours can do similar??
  11. olley
    olley Funster
    Jul 29, 2007
    3,746
    2,188
    Ipswich
    Hi Jim whats not safe about it? worst that can happen is the fuse blows.
    Olley
  12. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Hi Olley
    Bad choice of word, correct, it's not unsafe from a 'safety' point for charging but if you forget to remove the fuse on site and are not on ehu the engine battery could end up flat.. my meaning was to 'play it safe' and not have this happen.
    Jim
  13. aido
    aido Read Only Funster
    Sep 4, 2007
    70
    Co. Wicklow
    Jim
    Just going out to start mine now, same thing happened went dead over a period of 4 weeks will have to go solar:RollEyes:
  14. olley
    olley Funster
    Jul 29, 2007
    3,746
    2,188
    Ipswich
    Hi Jim thats why I fitted the battery master (crap memory) but was thinking Jim needs to save all his money for his birthday bash. :BigGrin:
    Olley
