Flat Battery/Removal Problem
Discussion in 'Motorhome Chat' started by Kool Kroozer, Jan 3, 2015.
  1. Kool Kroozer
    Kool Kroozer Funster
    Apr 19, 2014
    1,112
    1,815
    Cannock Staffordshire
    Peugeot Boxer cab 2013 Autocruise Rythm model - went to the van last week at the storage place and the battery didn't have enough juice in it to turn the motor over, a little like another thread regarding the battery going flat - I rang Peugeot to ask if it was ok to remove the battery so i could put it on charge, they said "NO as it could cause damage" - "try to jump it off the points under the bonnet" ...Now i remember very well when we purchased this van from Spinney they advised us "NOT TO JUMP IT FROM THESE POINTS AS IT CAN DAMAGE THE ECU" - So i rang Spinney and asked them if removing the battery was ok - "YES" came the reply, we do it all the time to about 30 MH otherwise they would all go flat... at this point i no matter what i did it was going to be wrong lol... so i decided to remove the engine battery, bring it home and charge it - took it back yesterday and fitted/started the van no problem - until i noticed a warning light on the dash display "EDB Failure" "ABS" "Engine management light on - speedo not working, Airbag light on Grrr - drove it home really pissed off as we planned to have a day out over the Peaks, got in it to go out and all the warning lights had gone an all working again... Got to castleton an had a bite to eat - got back in the van an all the lights back on again - Grrr - as luck would have it i stopped for some fuel right opposite a Peugeot Dealer - what the heck i gonna be a cheaky chap and go over - they looked at it FOC with the diagnostic computer and deleted all the faults and reset it all - all was ok again - went out to the van again this morning and all the warning lights back on again ! May i just say i have not revealed to Peugeot that i removed the battery, i just told them it was really low in power and only just turned over and started... Has anyone else had this problem ? If jump starting and removing the Battery is not an option how the hell you supposed to charge the battery if you have no 240v at a storage place ?
  2. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,302
    2,597
    Surrey
    Silly question, is the earth terminal correctly seated on the battery, or did you damage it when refitting?
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    And how do you replace the battery if it causes damage by removing it?
    The battery point under the bonnet is there for that very purpose.
    • Like Like x 3
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,182
    14,954
    Leeds the one up North
    Yes indeed the jump points were deliberately put under the bonnet because of the difficulty of accessing the battery.
    • Like Like x 1
  5. Kool Kroozer
    Apr 19, 2014
    1,112
    1,815
    Yes the earth lead is seated correctly, I am just wondering now if it has damaged the ECU... The battery in question is a new one and was replaced by Peugeot a few months ago - It is booked in for Wednesday with the dealership but i have a feeling if they reset the ECU it will just keep doing this.
  6. Kool Kroozer
    Apr 19, 2014
    1,112
    1,815
    Exactly my point PJ, wish i would have jumped it now - but even so would there not come a time when i would have to remove the battery myself - so if this is the case the outcome is inevitable
  7. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,302
    2,597
    Surrey
    I have to say it is sounding like a wiring issue, rather than an ECU fault. As has been stated, it simply cannot be true that removing the battery damages the ECU. The fact that the faults can be cleared, and randomly come and go leads me to this conclusion. Are the fault codes sensible, or seemingly nonsense?
    I'd be inclined to test the earth integrity from the battery to the chassis using a multi meter.
    • Like Like x 2
  8. pappajohn
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    In my experience, When jump starting do ot try to start immediately after connecting the leads and with the donor engine running.
    There's a chance the high voltage could spike the ECU.
    Instead, connect the jump leads with ignition off on dead van, start doner engine and run for 10/15 minutes to put some charge into the dead battery.
    This has the effect of smoothing out the available power once a start is attempted.
    never connect or disconnect a battery, flat or not, with the ignition turned on.
    • Like Like x 4
  9. andy63
    andy63 Funster
    Jan 19, 2014
    1,970
    7,176
    south shields
    hi sorry to hear your problems after removing the battery.. heard similar tales and had the odd thing happen with a car I had after removing the battery , but nothing like yours with fault codes.
    did you have the ignition on just before disconnecting the battery..only asking because on the transit I have now it takes a min or so for the bcm to shut down and i always leave it 5 min before disconnecting and the same again before trying to start.. don't know for sure it matters but never had to do anything other than re code the radio, and sometimes the door locks cycle a time or two..
    sometimes it takes a certain number of drive cycles for faults to clear.... hope it all gets sorted
    ta andy
  10. Badknee
    Badknee Funster
    Aug 25, 2014
    3,709
    15,896
    notloB
    Ok, let's think about this. Would a manufacturer spend money on fitting jump points if it was going to damage the vehicle in any way? I think not.
    What Pappajohn says is true, let the doner vehicle pass some charge into the flat battery for a while with the doner running about 1500 to 2000 rpm.
  11. Techno
    Jul 28, 2010
    14,182
    14,954
    I would be checking the battery voltage, new or not if it's been overdischarged it could be damaged. Check it before starting and again an hour after a run.
  12. Neckender
    Neckender Funster
    Oct 15, 2007
    1,048
    1,305
    Stoke on Trent or Benidorm
    I Don't know if this works but on another forum someone said when battery is disconnected touch together the battery positive and negative together, and this removes codes from ecu, then reconnect battery as normal.
    John.
  13. chatteris
    chatteris Funster
    Feb 15, 2014
    72
    64
    cambridgeshire
  14. Kool Kroozer
    Apr 19, 2014
    1,112
    1,815
    When the battery was removed the ignition key was on my trouser belt, the battery was about 12.8v when i fit it and went up to around 13.8v when the engine was running, strange thing was when all this happened was the time on the dash display and the time on the stereo was correct ! which was a little surprising as i thought i would have had to reset them.
  15. Techno
    Jul 28, 2010
    14,182
    14,954
    12.8 was after you charged it yes and the 13.8 is the alternator voltage. Have you checked the voltage since?
    As said in another thread you can measure the voltage at the fag lighter socket with ignition on. Or at the jump terminal
  16. Kool Kroozer
    Apr 19, 2014
    1,112
    1,815
    voltage right now (just checked) 12.6v
    • Like Like x 1
  17. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    1,980
    1,425
    Dover
    This is a problem with most modern cars, You need a battery saver that plugs into the permanent live accessory socket (cigarette lighter) and it keeps the voltage across the system whilst the battery is out.
    It also keeps the radio code alive as well as the ECU. I have not heard of problems jumping the vehicle as they even give me a special jump point to attach the leads to on my Transit, It is just a good easy access point to get to under the bonnet.
    • Like Like x 1
  18. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,657
    10,498
    Glasgow
    Well I wish we HADNT had the AA jump ours now. Our control panel regarding battery status no longer works
  19. Kool Kroozer
    Apr 19, 2014
    1,112
    1,815
    Yes Andy, 12.8 was the reading i took before i reconnected the battery and 13.8 was with the engine running, as said above its now 12.6v without engine running.
    • Like Like x 1
  20. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    4,753
    8,939
    Lorca,Murcia,Spain
    Quite correct. In Citroen manuals it specifically states that the leads should be connected to the car . The slave vehicle started & left running for at least 15 minutes before attempting to start to prevent ecu damage.
    Additionally there is also a specific way of disconnecting & removing /replacing the battery. Can't remember all of it but to remove you put keys in ignition , turn on , drop drivers window. ( What you do if the battery is completely dead I've no idea ?) then turn off ignition, shut drivers door. On no account must drivers door be opened whilst battery is being changed.
    Then remove & replace battery. Then there is some process , which I cannot remember in full, where you lean in through drivers window, turn on ignition & press this, flick that , etc; Apparently this resets the ecu. Then once all this is correct as per handbook , you then turn off ignition & can open door.All this was in the handbooks in both Spanish & the English manual.
    I have no doubt that all the other manufacturers have similar systems.I couldn't believe it.
    • Like Like x 1
