Flat Battery - need help
Discussion in 'Tech/Mech General' started by Southampton, Oct 24, 2012.
  1. Southampton
    Southampton Funster Life Member
    Dec 16, 2011
    514
    298
    Hampshire
    Just been out to the van (fiat Ducati 3.0L) and the vehicle battery is flat. Question is can I jump start direct on to the battery or will this cause other problems.
  2. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
    Yes, connect another battery with jump leads---leave for a while ,then try starting.
    If in doubt disconnect battery leads and charge up for a while with a charger
  3. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,157
    8,069
    DERBYSHIRE
    if you look in the handbook (page 158)you will see it has a battery jump connection point under the bonnet as the battery is under the floor
  4. Southampton
    Dec 16, 2011
    514
    298
    Hampshire
    Yes I saw that and when I connected the charger nothing happened so I was assuming this has a disconnect somewhere. I have connected the charger direct to the battery and it is now accepting a charge. Fingers crossed it should charge in a couple of hours at least enough to start.
  5. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,689
    5,841
    Mansfield,Notts
    If nothing happened when you used the under bonnet battery post one of two things spring to mind
    1.It has been disconected possibly during conversion
    2. You did not have a proper earth on the other charger lead, keep trying metal parts untill the charger shows signs of life:thumb:
    If still no result
    see 1.:Angry:
  6. Southampton
    Dec 16, 2011
    514
    298
    Hampshire
    Now got a fully charged battery and all I get when turning the key is a loud click from engine compartment. Any ideas anybody?
  7. rangitira
    rangitira Funster
    Jun 30, 2010
    6,316
    12,764
    Cornwall
    Just had this prob on my 02 1.9 tdi it was the solinoid
    (Starter was 15 months old:Sad:)
  8. jhorsf
    May 15, 2009
    9,157
    8,069
    DERBYSHIRE
    I do not know if this is relevant but I remember reading that Fiat had fitted a main fuse that was to small and blew on some vans?I cannot remember any more details but think it was a bigger fuse they had to fit
  9. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    Check all connections....battery, solenoid , starter motor, make sure all connections are clean and TIGHT.
    If jumping from another CAR have the engine running at quite a high-ish speed...let the engine of the donor battery run for a short while before you attempt to start......car batteries are a little on the short side of cranking power..if its another motorhome, Van, small truck, then fine
  10. jhorsf
    May 15, 2009
    9,157
    8,069
    DERBYSHIRE
  11. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,357
    9,807
    if it clicks, its not going to be the fuse
    try the relays in the fusebox behind the nearside headlamp or starter solenoid. It would help to know where the click is coming from.
  12. Southampton
    Dec 16, 2011
    514
    298
    Hampshire
    Thanks guys, had to go out earlier and it is to dark now so will look at the suggestions in the morning. I hope it is nothing too serious as I am due to trade it in next week for a new van. It's Sod's law, just when you don't need any problems they happen. Thanks anyway, will check it out tomorrow.
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,316
    YO11 2BD
    Just a click......probably a poor earth to the engine.
    the earth may be good enough to allow a low amp current....key to starter solenoid, just a couple of amps maybe....but once the starter solenoid kicks in the cranking current is massive and the earth may not cope.
    • Like Like x 1
  14. Southampton
    Dec 16, 2011
    514
    298
    Hampshire
    Sorted
    Got it sorted. It was the main in line fuse from the battery, the CAL 5 fuse. Had a 30 mile round trip to get one but all okay again now. Apparently speaking to the Fiat man this is not an uncommon fault. Anyway thanks guys...oh and the charging posts now show a voltage, so if no voltage across the charging posts first check the fuse on the battery terminal.
