- Jul 1, 2010
- 3,198
- 33,486
- Hymer B 588 DL
- Since September 2010
Evening all,
Went to pick up my Autotrail Tracker this morning after 34 days in storage, found the engine battery totally flat, not a glimmer even the fiat display (clock) was blank
Took some time to get it jump started. The alarm was not set when it went into storage so no battery drain there, I'm at a loss as to why it should have happened. Battery was fully charged on the day it went into storage which is 30 miles from home so it had a good run.
MH first registered 1st Sept this year, so battery should be good, we made sure everything was off prior to leaving it.
Totally perplexed so I ask you my learned peers what could be causing it, I work away from home at sea for 4-5 weeks at a stretch so MH needs to stand for a month without charging.
Many thanks in anticipation
Stewart
Stewart
