Do Not attach to battery terminals!
the jump post under the bonnet is connected directly to the battery so if you can be bothered to access the battery then carry on....but the post is easier.Why`s that ? I thought that was the way to do it. It worked in 1979 on my mini 1000
You might fry the ECU if you connect jump leads with the ignition turned on....sudden volt surge....but if the ign is off its no different to having a normal fully charged battery.On a modern vehicle you can fry the ECU if you connect direct to battery!
No it isnt...its because the battery is inaccessible.That is why Fiat supply a + connection under bonnet!
Come orrrrn.....you can give a better argument than that.
Not FIAT but Ford state that the negative connection should be made to the body earth & not the negative battery post, & it's ok to connect the positive connection to the battery positive, or in FIAT / SEVAL vehicles to the positive post under the bonnet.
My 2014 Mondeo has no access to the battery negative post.
My 2010 Mondeo doesn't either but there is a -ve post next to the battery case
