flat battery & blown fuses!
Discussion in 'Tech/Mech General' started by Elvis, Sep 2, 2009.
  1. Elvis
    Elvis Read Only Funster
    Jun 13, 2009
    294
    45
    London
    We are still having electrical issues! Engine battery is fine now - that was a loose earth wire! But still getting blown fuses and a flat leisure battery :Eeek:
    A few times now, we have got ready to set off for the weekend and found our leisure battery flat and/or a fuse blown; one was actually melted!:Eeek: We checked around and could see that nothing had been left on and we had only been out in it a week before and all batteries were fully charged when we parked up!
    Any ideas?
  2. sinbad1
    sinbad1 Deleted User
    Sounds like something is drawing a large current to blow the fuse, perhaps there is some drain from a component even though its not switched on you could try:-
    1. Turn off engine and everything that uses current.
    2. Disconnect the negative (-) battery cable from the battery.
    3. Place a test light between the negative battery post and the disconnected cable. If the test light
    glows, either some electrical accessory is still on or there is a short that is draining battery current.
    4. If the test light doesn’t glow there is no current drain.
    5. To find the current drain, disconnect (one at a time) fuses and electrical components until the light
    stops glowing. When the light stops glowing that component or circuit contains the current drain.
    regards
  3. Tony Lee
    Tony Lee Read Only Funster
    Sep 28, 2008
    274
    Which particular fuse is blown. The diagnosis may depend on which one it is and what size fuse it is.
  4. Shubberdog
    Shubberdog Deleted User
    Is the leisure battery remaining connected when you start up and trying to share the load of the starter motor i.e. Sticking contacts on a split charge relay :Sad:
  5. N&K
    N&K
    May 26, 2008
    220
    42
    Berkshire
    We kept getting a flat battery , it turned out to be the glove box light not turning off when the glove box was shut. We even bought a new battery thinking our battery was on its way out, the new battery went flat too. we took the bulb out, problem solved! Try another battery if you can borrow one before buying a replacement and see if that goes flat.
    We also had a melting fuse, this turned out to be a stop/tail light bulb in one of the ceiling lights, (i.e a bulb with two base terminals instead of one, which was causing a short). Might be worth checking all your bulbs.
    N&K
  6. Elvis
    Jun 13, 2009
    294
    45
    London
    That's just it - 3 different fuses have blown, different uses. We think our leisure batt is on it's way out - could a dodgy batt blow the fuses or drain totally flat in 5 days (static) ?
  7. hilldweller
    Dec 5, 2008
    27,567
    26,682
    Macclesfield
    We've just had something similar on here - but it was the alternator faulty and putting too many volts.
    I wonder if a faulty charger has cooked the battery and blown the fuses ? Small chance.
    Has anyone touched the electrics ? A million to one, the leisure battery wired in series with the engine battery giving you a 24V leisure feed. This is *just* possible if the negative of the leisure battery touched the starter battery positive.
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    if the batteries knackered it will be drawing a massive amount of current to try to charge it and it will self discharge in no time.
    shouldnt blow the fuses though, they are there to protect the wiring from overload/melting caused by a faulty appliance or damaged/short circuit wires.
