Flat as...
Discussion in 'Tech/Mech General' started by Phyly, Apr 8, 2010.
  1. Phyly
    Phyly Read Only Funster
    Sep 17, 2009
    11
    South Coast
    Went to my 'van which is in storage and the 'van battery is flat:cry:
    Can I just use jumper leads from my car, a 2.0lt diesel to jump start the 'van? or do I have call out the boys at Green Flag.
  2. dikyenfo
    dikyenfo Read Only Funster
    Aug 29, 2007
    44
    lincoln
    Connect the live terminal battery to battery and then connect the car battery neg. to the chassis on MH. Run car engine and then operate starter on MH. Good luck
  3. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,660
    14,439
    North Lincolnshire
    Connect it as in previous post and it should jump start.
    It's only a van after all.
    John
  4. Phyly
    Sep 17, 2009
    11
    South Coast
    Many thanks...you keep hearing horror stories about people blowing the electrics in the donor car!!
  5. wildbri
    wildbri Read Only Funster
    Dec 16, 2009
    27
    It is suggested that you turn on lights and heater fan in the vehicle to be started before you jump start to prevent a surge from the vehicles alternator when it starts, this can damage the electronics on modern vehicles, or so I am told. regards bri :Smile:
    P S I have started many vehicles without doing this and have had no problems, but with modern electronics who knows..
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    depending on how flat the battery is and how long it's been like it it may now be dead, better to remove it and charge it properly rather than start and drive someplace only to find you still have a flat battery when you try to restart to come home.
    Good luck
  7. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    Phyly........under my Fiat bonnet on the right is a black plastic cap with a + sign on, lift the cap to connect the red + positive lead on, and on the front bodywork above the front grill to the right is a nut and bolt with a long thread showing and stamped at the side into the panel is the earth sign..... one line vertical three lines horizontal getting smaller to the top (Like a christmas tree stood up or on its Side)..clip your - earth to that.
    MEL:thumb:
    (Thats is on the latest Fiat 130 multijet 2008 model)
