Flashing LED's (1 Viewer)
ShiftZZ
21,383
84,550
Dark Side of the Moon
If I buy a number of Flashing LED's and joining them all up to a 12v supply,will they work?
Is there an easy way of doing it, remember that I have very little electrical knowledge..
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
What are they for? to bluff an alarm setup? or what?
D
Deleted member 29692
Yes, no reason why not.
There are lots of ways to do it, it all depends on what they are for and where they are going.
ShiftZZ
ShiftZZ
21,383
84,550
I was hoping to connect a load of leds to give the impression of a complex alarm system,, just a thought,
Lenny HB
53,413
149,897
On the coast in West Sussex
Hymer B678 DL
What type are you looking at?
If it's the ones advertised as 12v flashing LED's that have a built in resistor you can just connect as many as you like in parallel.
If it is individual LED's you will need a current limiting resistor in series with them you can put a resistor in line with each LED and then paralell them, or if running on 12v you could put up to 6 LED's in series with a single current limiting resistor feeding them.
Don Quixote
2,966
5,258
VW T6 Campervan
The simple way to do that is buy these:
Broken Link Removed
No wiring or cutting into anything. The battery lasts for about a year if they are on 247/365. Next time we meet up you can have a look as I have them on all windows on 247/365 as a backup for the alarm system.
Lenny HB
53,413
149,897
Hymer B678 DL
Broken Link Removed
They look interesting is the small button on them the on/off switch?
ShiftZZ
ShiftZZ
21,383
84,550
So if I bought these
And then linked them to a 12v supply they would flash at different intervals or all at the same time?
Series or parallel?
MicknPat
614
3,606
Touring UK
39ft American A class RV
Since Oct 2007
Here you go ShiftZZ how about these?
Jim
Ringleader
Jul 19, 2007
36,403
130,772
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Series or parallel?
I doubt they would flash together unless they were hooked up to a central controller.
Chris
21,051
278,604
None
10 years
You should get a Growler fitted it has flashing LED's.
@eddievanbitz will sort you out.
Feb 24, 2013
13,078
101,442
Bolsover, Derbyshire
Hymer S800
not long enough
has anybody else parked next to a Vanbitz alarm and found it annoying?
blue flashing lights outside at night are a little concerning in the early hours
and while on the subject, why do alarms need to make so much noise when they 'unset' at ungodly hours it is really annoying, locking I understand the need / desire to confirm setting, the whole camp site does not need to know you are home again :mad:
as for OP, not got a clue :)
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
these are what you want
Broken Link Removed
they already come with connectors to connect end to end and lots of effects including white light.
Cheap as chips got some in the van for rallies.
Chris
21,051
278,604
None
10 years
Says the man who has just bought a genny :D
Jim
Ringleader
Jul 19, 2007
36,403
130,772
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I love those vanbitz blue flashing lights, they scream, "go and rob someone else" However, vanbitz now do a high and low-profile light deterrent, so you can choose with the flick of a switch to have the lights very bright and unmissable, or just a soft glow for when on a campsite or similar. (y)
