Flashing Fridge Control Panel ? (1 Viewer)
etap
256
228
Somerset
Chausson Flash 610
3 years
Just back from a trip to the heel of Italy which was great, however, the new fridge on our new Chausson 610 ( not automatic) Thetford would not always hold itself on mains, it often turned off and the display flashed, the fridge worked well on gas and also on 12volt, so been thinking maybe the electric power on sites we used ( mostly acsi sites) did not have enough amps.
Before I contact Thetford was wondering if anyone could throw some light on the issue, be greatful for any help.
Etap
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I would guess the mains power supply is unstable and producing low voltage. ... best stay on gas ..... Our fridge was damaged when this happened to us in France.
If you have a tester it is easy to check the supply.
etap
etap
256
228
Somerset
Chausson Flash 610
3 years
Thanks icantremember, which tester and how to test would be helpful, especially testing for amps.
Etap
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
I agree------we have seen quite a few fridges switch to gas when on EHU-----usually when breakfast power draw is on and voltage can be as low as 150volts------just leave on LPG during this time
I believe it's VOLTS that you want to check
icantremember
8,333
17,545
Hymer T-SL668
since 2005
Etap
As @Sundowners said it is volts you need to check and any mains tester should do this.
If you don't have a tester available then stick with gas until you are on another site.
golly
2,005
69,615
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Thetford fridges are notorious for a problem with the PCB. Ours went kaput on our first trip away and I have heard of a number of similar problems.
Feb 24, 2013
13,079
101,442
Bolsover, Derbyshire
Hymer S800
not long enough
From what you are saying was it alright once you got out of Italy, or when back home?
That does rather support your own thoughts and those above, weak voltage (y)
I have read that fridges are more efficient on gas anyway and I don't think they use too much
etap
etap
256
228
Somerset
Chausson Flash 610
3 years
Thanks for your replies.
Trouble shooting guide says try another power source.
Have not tried it at home yet, although sometimes abroad it worked well in places you wouldn't expect it to.
I try not to get into electrics too much too little knowledge, but I do have a £5 tester which I use for batteries, is it possible to use this for voltage testing? If not is there a tester I can buy and use myself for testing voltage on site? Be great if I could as we used 15 campsites on our way to Puglia over the last month.
Thanks again
Etap
Jaws
23,836
72,460
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Our Thetford kept dropping out on mains when in Croatia
Got the meter out and found at peak use times on the site the voltage was dropping to just under 200.. That is all it was
