Flash Magic Eraser (1 Viewer)
Dec 12, 2010
5,368
21,198
Cumbria
since 2011
Picked one of these up on a whim in Tesco, thought I might try it on some stubborn small black spots on the m/h roof (although it says not to use on car bodies ) and it worked a treat. Also cleaned up the greying surface of the mastic seal around the hab door frame and cab/roof joint. It doesn‘t appear to be abrasive but does have a detergent incorporated in it that‘s activated when you wet it.
GJH
29,450
38,828
None, now sold
2006 to 2022
I've never used the Flash brand but have used others on our previous van (the ones without added detergent). They did work but it's always best to try first on an inconspicuous area.
Oct 20, 2013
5,299
12,787
South Norfolk
Yes
I've never used the Flash brand but have used others on our previous van (the ones without added detergent). They did work but it's always best to try first on an[HI] inconspicuous [/HI]area.
Easy for you to say :wine:
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
IT TAKES THE SURFACE OFF HIGHLY POLISHED / PAINTED THINGS --OK for occasional stubborn spot but be very careful on paint :Eeek::Eeek::Eeek:::bigsmile:
edit you can buy 4 duzz- it ones in some pound shops --brill bits of kit but you have been warned
terry
5,024
5,806
West Yorkshire
PVC
since 2008
Its strange that this subject has been brought up.
I have recently started to stock these for selling at shows. They are phenomenal at cleaning glass and many metals. I have been testing them on all sorts of stuff. They get scuff marks off plastic car interior parts that I have tried all sorts on. I am going out now but will add my list of things I have tried it on later.
Oct 29, 2008
5,024
5,806
West Yorkshire
PVC
since 2008
Ive found them good for removing burnt on plastic from a chrome toaster, cleaning stainless steel hob, microwave, coffee machine. Renoving printer ink stains from a desk. Removing coffee stains from cups. Removing marks on fridge interiors. Cleaning alloy wheels.Removing marks from emulsion walls and gloss paint. Cleaning ceramic tiles and grout joints. Stainless steel and ceramic sinks. I have tested them on the grp sides on my van and found that they remove black streaks.
I am well impressed with them, they remove ingrained dirt that normally is impossible to remove.
Jul 26, 2010
662
901
Bristol
Hymer B584
since May 2010
Had to go out and buy these today :winky:
I am impressed - I managed to remove old stains from tiles and clean limescale off the sink, all by wiping rather than having to scrub.
Only criticism I have is that they're not very robust. I've managed to pretty near destroy one within a few minutes. :Doh:
Still I'm enthused enough to want to tackle the grout in the bathroom :Eeek:
MattR
4,083
37,392
Beds
Panel van
Years
I use these regularly for removing scuffs from paintwork (walls & wood) - they do disintegrate so I've started using the tub version and the pad that come with it or my own sponge - it is cheaper and a bit tougher so better for some stains. Well worth using :)
http://www.jmldirect.com/invt/d03dp30100000001?gclid=CJqoqrSjmr0CFeKWtAodYRYAWA
MHVirgins
3,889
3,158
South of Scotland
March 2011
We've been buying a similar product from QVC for a couple of years.
They are made by a Canadian company (It Works!) and were originally used as insulation in aircraft and are a type of melanine.....according to the guy who demonstrated them on QVC shopping channel.
We've used them all around the house and the mh, they even take black streaks and other stubborn marks off. We've got a white Astracast kitchen sink at home and these are the only things that remove stubborn marks from it. Even Mr Muscle failed to remove some stains and the It Works cleaning blocks did:thumb:
http://www.qvcuk.com/It-Works-Set-of-20-High-Density-Cleaning-Blocks.product.800513.html?sc=800513-SRCH&cm_sp=VIEWPOSITION-_-3-_-800513
They do disintegrate after several uses and if you rub too hard on certain surfaces. But don't squeeze or wring them out, just press between the hands to remove excess water before use. But overall we thought they were brilliant and they are non-abrasive.
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
Don't you belive they are non abrasive ::bigsmile: they definitely take the gloss off painted sufaces:Smile: I have the tee shirt to prove it :winky:
Alsi the JML stuff is as well :Smile:plus you can buy tubs of Astonish that's the same but you can find it for 1 pound ish :winky:Been using it for around 15 yrs and the sponges for around 10 yrs both excelent products ---sponges are 4 for a pound from guess where ::bigsmile: go by the name Duzz it or magic erazer:Smile: I have a small stock of around 6 boxes of 4 but family members keep begging them ::bigsmile:
terry
Oct 29, 2008
5,024
5,806
West Yorkshire
PVC
since 2008
They are mildly abrasive. If used on high gloss paint the surface shine may need to be polished back up. I have tested them on black stripes and they work well, They are also great at removing flies from the windscreen.
I found the secret is to be gentle to start with and if the dirt is not removed you then put more pressure on. Brands do vary in quality I have tested a number of different brands and there are some very cheap ones that seem to disintegrate on first or second use and there are some that last a lot better.
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
WELL? you can't say that without letting us know the results, please:RollEyes:
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
They are all made from the same type of sponge-cannot remember the name but Ilooked into buying large sheets of the stuff yrs back --tried all sorts of brands and no difference --JML,ASDA,B&Q DUZZ-IT Aldi and pound shop ones --pay your money and make your choice but I found no difference -family still nick em ::bigsmile:
terry
sedge
Jul 7, 2009
5,494
13,029
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Did they work on the grout? - neat extra thick bleach works I've found, but is a PITA and needs a nice day as you certainly need lots of AIR ....
Oct 29, 2008
5,024
5,806
West Yorkshire
PVC
since 2008
terry
They are available in different density and even colour now.
