Fixing awning / draught skirt rails to MH
Discussion in 'Motorhome Accessories' started by Danceswithwolves, Apr 9, 2014.
  1. Danceswithwolves
    Danceswithwolves Read Only Funster
    Apr 8, 2014
    9
    15
    Barnsley
    Don't know if this has previously been covered ( I suspect it probably has )
    I needed to fix awning & draught skirt rails to our new MH .
    After hours of thinking about it & researching various products ( & prices )
    I decided to go with the slimline anodised aluminium type rails with no screw holes.
    I didn't want to be drilling holes and putting screws into the side panels to attach it & wasn't too keen on the colour of the aluminium when everything else on the side of the MH is white or black.
    I measured out & cut the lengths needed then chamfered and rounded the leading ends with a disc sander.
    I then spray painted them white using radiator paint which is non yellowing & very tough .
    I marked the position of the rails onto the MH with small pencil marks making sure the area where the rails were to be fitted was very clean .
    I then bonded the rails to the MH using HA6 rtv marine sealant / adhesive by Bond It . using a sealant gun, run a good bead of adhesive down the full length of the rail & carefully postion on the MH guided by the small pencil marks, then hold in position for a couple of minutes until the adhesive grabs. I then carefully run a thin bead top and bottom and smoothed it down with my finger tip.
    End result is a superb neat & tidy job that blends in really well.
    Leave to set for at least 12 hours before fitting anything to the rails.
    The bond is really firm & no screw holes in your pride and joy :thumb:
    • Like Like x 6
  2. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    sounds great, any pic's
    • Like Like x 1
  3. Danceswithwolves
    Apr 8, 2014
    9
    15
    Barnsley
    Sorry , Im a newbie - How do you post pics :Confused:
  4. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,366
    9,811
    sorry but silicone based sealants and glues dont work well long term on motorhomes. sikaflex 221 polyurethane is a better option
    • Like Like x 1
  5. TheBig1
    Nov 27, 2011
    7,366
    9,811
    on the reply to thread page, there is a toolbar at the top above the text area. click on the icon of a picture and add its address. or scroll down and click manage attachments to upload from your computer:thumb:
  6. Danceswithwolves
    Apr 8, 2014
    9
    15
    Barnsley
    Its not silicone based - its a marine sealant / adhesive that's uv & salt water resistant and unaffected by extreme temperatures ( -60c to +200c )
    Sikaflex 221 = £12 a tube or Bond It HA6 = £3.58 a tube .
    • Like Like x 1
  7. Baycott
    Baycott Funster
    Nov 6, 2013
    6,367
    11,505
    East Sussex
    Sounds like a good job.
    Would love to see some pics.
    By the way welcome :welcomefunster:
  8. Danceswithwolves
    Apr 8, 2014
    9
    15
    Barnsley
    • Like Like x 6
  9. UK Pete
    UK Pete Read Only Funster
    Jan 16, 2014
    285
    334
    kent
    Good job that looks really neat
    pete
  10. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,240
    10,734
    E Yorks
    Hi 'Wolfie' :BigGrin: ! Welcome to the fun house! :thumb:
    Nice job there, I also wanted a draught skirt for our PVC conversion but I couldn't fit a rail due to us having a sliding door and there being no room under it to put one, so instead I made the following:
    I used the bottom section of an old awning (about 18" high including the 6" 'plastic skirt material' on the bottom) - I had to join 2 pieces together so it was long enough to run the length of the awning that we use. I then folded over the top of the material to make a 1 inch slot running along the full length (this reduced the height to about 15") and threaded through some heavy duty elastic which I pulled tight so it was under tension. I sewed the elastic to the material it at each end of the slot to stop it 'disappearing' back into it when it was let go! I left some excess elastic sticking out and made a couple of large 'loops' to thread straps/bungee cords into. As I used the bottom of an existing awning it already has some pegging straps attached, so I just added a couple more and also some eyelets in the 'plastic skirt' part.
    To secure it to the van I used elastic with hooks on the end (a bungee cord of a suitable length would do though) - at the front I hook it onto the wheel arch behind the front wheel, and at the rear it hooks onto the back of the rear wheel arch (there's a nicely located bolt!). I use tent pegs for the straps and mushroom type pegs through the eyelets to hold it down to the ground. In addition I also used a few strong bulldog clips to holds the top to the underside lip of the van so it didn't get trapped in the sliding door although I have now got some nice strong plastic clips to replace these which won't cause any damage to the material as bulldog clips could tear it.
    I used it when we went to the Newark show and despite it being very gusty and the 'skirt' being on the receiving side of the wind which was coming under the van, it worked a treat keeping the cold wind out of our awning totally.
    The only downside is that the electric step can't be used as it is covered by the skirt but we have a plastic folding step which does just as well. :Smile:
    • Like Like x 3
  11. Danceswithwolves
    Apr 8, 2014
    9
    15
    Barnsley
    Just thought I would mention, The full length bottom draught skirt is grey and 5.2m long to match the awning. The top of the wheel arch section ( tag axle ) is covered by a white piece of vinyl connected to the bottom skirt with plastic figure of 8 track & fastened to the MH at the top by 3 studs with 3M adhesive white discs that stay on the vehicle.
    Nice neat & tidy job if I say so myself - :coolthumb:
  12. Minxy Girl
    Aug 22, 2007
    9,240
    10,734
    E Yorks
    Flipping heck, on here five minutes and already getting cocky!!!! :Rofl1::Rofl1::Rofl1:
    • Like Like x 2
  13. Danceswithwolves
    Apr 8, 2014
    9
    15
    Barnsley
    :youbetcha: :Laughing:
  14. Angela Dyer
    Angela Dyer Read Only Funster
    Jan 7, 2015
    54
    10
    Worcestershire
    Thank you Dancewithwolves this has helped me immensley.xxx
  15. Angela Dyer
    Jan 7, 2015
    54
    10
    Worcestershire
    How do I keep this for reference please.x
  16. chrisboyo
    chrisboyo Funster
    Aug 5, 2009
    1,338
    825
    Newport South Wales
    Could you tell me where you got the rails from please
  17. Suecclassic
    Suecclassic Funster
    May 20, 2015
    6
    Newcastle under Lyme
    I would also like to know where you got the rails from and the other elements. It looks like you have done first class job.
  18. scotzsue
    scotzsue Funster
    Apr 11, 2015
    779
    716
    hull
    Looks like a solution for us too, wonder how top rail will cope with the weight of an awning though. don't know how supportive silkaflex or what you used is. Like the idea of the radiator paint too, wonder if it is available in other colours.
    Well done, neat job
    Bungy DL we got rail from a local caravan repair place.
  19. Suecclassic
    Suecclassic Funster
    May 20, 2015
    6
    Cheers Scotzsue
  20. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,554
    5,638
    West Sussex
    Nice neat job. I looked up HA6 it is silicon I think I would have paid the extra for Sika.
