Fixed clipboard
Discussion in 'Fiat' started by Bilbo Baggins, Feb 26, 2014.
  1. Bilbo Baggins
    Bilbo Baggins Funster
    Jan 24, 2013
    35
    9
    Near Bristol
    Hi everyone.
    My 2.3 Ducato seems to be one that has a fixed clipboard on the dash.
    Surely I could change this to make it useable. Has anyone done this and how do I get the fixed one to lift up. Was this just a cost cutting exercise just to save a couple of pounds, or for some other reason.
    Hope someone can help.
    Peter.
  2. treetops1
    treetops1 Funster
    Feb 25, 2013
    917
    1,046
    yorkshire
    Hi .I have one on the Rapid and i use to clip my sat nav in situe and its great would not be without it lol.:thumb:
  3. Bilbo Baggins
    Jan 24, 2013
    35
    9
    Near Bristol
    I though of that, and may have to accept that it can't be changed.
    However I do like every thing to be as it should.
    Thanks, Peter.
  4. iandsm
    iandsm Funster
    Jan 3, 2008
    1,575
    2,739
    Suffolk
    When you say fixed, do you mean you can't lift it up on the hinge, i.e. pull up from the front?
  5. Bilbo Baggins
    Jan 24, 2013
    35
    9
    Near Bristol
    That's exactly it. Not useable as a clipboard as it slopes away from you.
  6. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,376
    9,823
    grab the end nearest the windscreen and pull hard, it is often very stiff but will pop up. not found a solid one yet
    • Like Like x 1
  7. Bilbo Baggins
    Jan 24, 2013
    35
    9
    Near Bristol
    May risk it.
  8. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,973
    2,802
    Kendal, Cumbria
    I thought they all lifted too. It is very easy to remove the whole module if it won't lift & you need to examine it in detail. The steps are:
    Remove radio & (tin) radio 'cage'.
    Remove two screws inserted at an angle that were hidden by the radio
    Remove two screws at the end nearest the windscreen
    Lift out the whole unit.
    If it is a fixed lid then the screws to do that will be visible on the underside. It is a useful piece of kit - not so much as a clipboard but I've removed the sprung support that holds it in the 'up' position leaving room for a unit of 4 cigar lighter sockets and space to keep coins or keys. I'm investigating a spare one I bought to see if it could be hinged at the windscreen end to provide a place in the shade for a rear view camera monitor.
  9. Tobym
    Tobym Funster
    Mar 26, 2013
    32
    23
    Glasgow
    Could be wrong but I think if you have a passenger air bag fitted then the clipboard is fixed in position for some reason
    • Like Like x 2
  10. SandJ
    SandJ Read Only Funster
    Sep 14, 2007
    1,558
    518
    North Yorks
    I was just going to say the same:thumb:
    Will see if I can find other info:thumb:
    • Like Like x 1
  11. Sidney
    Sidney Funster
    Jan 27, 2013
    1,175
    750
    Stamford
    Don't!
    The newer x250 Ducato "Born to be a motorhome" does not have the hinges or foldaway mechanism at the back.
    This was changed when they incorporated the ability to change the clipboard for the blue and me system.
    I discovered this and had to persuade the clipboard back into place :Blush:
  12. SandJ
    Sep 14, 2007
    1,558
    518
    North Yorks
    See
    1 Jul 2010 - 1 Due to European legislation, vehicles with a GVW of over 4000kg include a tachograph and speed limiter 56mph/90kph as ... Central dash folding clipboard ( deleted with passenger airbag) ... Dual cab passenger seat - fixed.
    A statement from
    http://business.peugeot.co.uk/Resou...onversion-prices-and-specifications-fleet.pdf
    Also mentioned on other sites.
    It seems if you delve into other posts the airbag stuff is not under so some say but do your homework:thumb:
  13. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,068
    DERBYSHIRE
    I was told passenger airbag it does not lift
  14. TheBig1
    Nov 27, 2011
    7,376
    9,823
    i have passenger airbag and mine lifts but very very stiff at first. obviously if its been deleted on the last year or so model then i missed that. personally i see no point in the retaining clip being there still without the ability to lift it up
  15. Bilbo Baggins
    Jan 24, 2013
    35
    9
    Near Bristol
    Thanks for all your replies.
    Thought this was going to be a simple question, but seems to be getting more complicated. Need to sit back and consider my options.
    Peter
  16. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    what about emailing Fiat and asking them the question????
    Good luck and let us know the outcome xxxx
  17. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,880
    2,252
    Lincs
    It's certainly the case that newer vans with a passenger air bag do not lift.
    This definitely applies to 2013 on, but may also include earlier years.
  18. Sidney
    Sidney Funster
    Jan 27, 2013
    1,175
    750
    Stamford
    My current clipboard does not lift. The clipboard on my last unit did lift - but it wasn't much use anyway (I hardly ever used it as it wasn't in the best place/angle)
    • Like Like x 1
  19. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    I find the clip board clamp very good for grabbing (and holding) Stan, our Funster Bear, by the gonads so he has pride of place on the dashboard and enables him to lighten every child's heart who is in front of us - they all wave to him.
    :Laughing:
    Trikeman.:Wink:
    • Like Like x 1
  20. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,283
    10,777
    E Yorks
    We have a 2012 built base on our Fiat which was registered in 2013. The clip board does NOT lift on ours and we were told by the dealer that it is because we have a passenger airbag.
    On a previous vehicle we did have a lift up clipboard but it was as much use as a chocolate teapot as it obscured vision for the driver when raised to a 'usable' level! :Doh:
