Fitting solar panels - non electrical side
Discussion in 'Solar Power' started by oldun, Apr 26, 2009.
  1. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    My PVC is based on a Renault Master van which has a a series of raised strengthening ridges running across the roof.
    This makes the use of the standard type of bracket unusable at the ends or corner of the panel, If used at the side the length of the contact between bracket and roof would be quite small due to the small width of the raised sections.
    Can anyone offer me a suitable method of fixing these panels to such a roof?
  2. sinbad1
    sinbad1 Deleted User
    2 lengths of aluminium angle, suitable length screwed to several ridge points to support your solar panel/s.
    Regards
    How come your user name has changed djchapple ?
  3. scotjimland
    Jul 25, 2007
    28,988
    25,681
    Suffolk
    Same idea as Sinbad but I would use U section on it's side.. this give you two faces for fixing with access to the fixing nuts..
  4. oldun
    Mar 23, 2008
    748
    160
    St Neots
    Once again it's easy when you know how.
    Many thanks
