Fitting Snipe 2 question
Discussion in 'TV & Satellite' started by Billy23, Apr 13, 2016.
  1. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,564
    2,868
    On a planet...far, ....far away.
    I am waiting for the delivery of a Snipe 2. I am wondering how many cables have to be feed through the roof of MH. Also are they (Snipe)fairly easy to fit? I am thinking of taking the old TV aerial off and passing cables thought that hole, is that a good idea?
    Thanks for any help.(y)
  2. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,516
    6,494
    West Sussex
    There are 2 cables (Tuner & controller) with "f" connectors fitted to the ends. Doing what you suggest sounds like a good plan, should be able to mount the mounting plate with Sikaflex.
    • Useful Useful x 1
  3. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,564
    2,868
    Thank for that information, just what I needed.(y)
  4. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,564
    2,868
    I have today received my Snipe 2 and notice that in the fitting instructions they suggest fixing it in the middle of the MH. I was thinking of fixing it nearer the edge.
    Have any of you guys fitted one and if so, could you tell me your thoughts please, as once fixed, it would be a bugger to relocate.
    Thank you for your help.
  5. RowleyBirkinQC
    RowleyBirkinQC Funster
    Sep 20, 2014
    771
    1,791
    Dazed & Confused
    2015-08-26 19.50.49.jpg We have the original Snipe, ours is not centrally mounted on the van (pictured when not having parked correctly, been ok since).
    • Like it Like it x 1
  6. Steve N Tracy
    Steve N Tracy Funster
    Jun 1, 2015
    230
    133
    Southampton
    We have the Pro-Max version and its not fitted in the middle., its not caused any issues yet.
    • Thanks Thanks x 1
  7. mowbotman
    mowbotman Funster
    Aug 10, 2008
    197
    181
    Nottingham
    I fitted the snipe2 last week , very easy to fit and works a treat
    • Useful Useful x 1
  8. scotjimland
    Jul 25, 2007
    28,941
    25,636
    This is good practice with any dish.. the reason being, if the van moves when you walk about, or by gusts of wind .. the up and down distance is greatest at the edge of the van.. in the centre it is zero..
    In saying that, I mounted my Alden sat dish off centre as I had no other choice..
    • Useful Useful x 1
  9. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,803
    6,064
    Mansfield,Notts
    You seem to have generated an inordinate amount of waste fitting the snipe, judging by the Skip:doh:
    Geo
    • Funny Funny x 2
  10. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,564
    2,868
    Another question guys: The Snipe is pre set to receive up to about 9 satellites, I thought you had to have a different receiver for each satellite. Is it possible to have just one receiver and it will feed all of the satellites through it? I have an Icecrypt 1600 so that I can pick up British TV down in Spain, would that pick up the other sats? if not what receiver do you use?
    And a big thank you for your replies so far :)
  11. RowleyBirkinQC
    Sep 20, 2014
    771
    1,791
    Dazed & Confused
    I use an Avtex TV with inbuilt free to air Satellite receiver. It lacks the niceties of a dedicated satellite receiver in terms of EPG etc but works well enough for us. Only used it in anger on Astra 2, think you can change the satellite in TV settings if required to match that the Avtex controller is pointing at?
  12. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,564
    2,868
    I am now ready to stick the Snipe plate to the roof. I have Sixaflex 221 or CT 1 my question is which one is best. I am thinking that I would not screw to the roof just use one of the above. All help welcome, thank you.
  13. Charlie
    Charlie Funster
    May 16, 2015
    2,544
    3,024
    Is sikaflex really strong enough ? I mean permanant and strong ?
    I would love to add a Snipe 2 to our van. !!
    Not sure I'm up to installing it though....
  14. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,564
    2,868
    @Charlie well I am hoping somebody will tell me that either sikaflex 221 or CT1 is strong enough as like you, I am not sure. I might well bit the bullet and screw it down as well. :)
  15. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,614
    3,440
    Telford, Shropshire
    I would put at least a couple of stainless self tappers in as well. Sikaflex is easily capable of holding the Snipe in place as long as the surfaces are properly prepared but bear in mind you will be gluing to paint and you don't know how well the paint finish was applied (White Fiat vans have a history of the paint falling off for example). Just put a gob of Sika in the screw holes before you fit the screws.
    D.
    • Informative Informative x 1
  16. Charlie
    Charlie Funster
    May 16, 2015
    2,544
    3,024
    Knowing paint as I do I would not be confident in sikaflex or any kind of adhesive alone. I also worry about if for some reason the thing had to be removed what the result would be ?
    There are that many holes in a MH roof would a couple more matter ?
    This mounting plate... Does it come with the Snipe or as an extra ?
  17. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,564
    2,868
    Yes it comes with a very good mounting plate, and has screw holes, so I guess I will put some screws in it. I won't remove it as the Snipe will be sold with the MH as by then I will have had the use of it and of course it will perhaps help sell it.
  18. mowbotman
    mowbotman Funster
    Aug 10, 2008
    197
    181
    Nottingham
    I agree with Charlie cannot rely on the paint on a Ducato roof, mine is peeling in some places, I used silkaflex and all the screws, as the unit does sit quite high and would get some leveridge in the wind, when driving 50 to 70 mph, being has you can buy the mounting plates separate, I would leave the plate on, and just in bolt the dish if I sell
  19. RowleyBirkinQC
    Sep 20, 2014
    771
    1,791
    Dazed & Confused
    My thoughts exactly, unless of course you want an excuse to buy a new toy!
  20. ukdw
    ukdw Funster
    Dec 16, 2015
    19
    15
    Essex
    I too am looking into snipe2 installation on my roof. Tried using it the weekend by placing it on the roof through the roof light, got quite wet when I brought it back :) - so definitely want to permanently mount it.
    Am thinking of making use of some old solar panel brackets that are already there, with a framework of angled aluminium between them, the snipe roof mount and Silkaflex. Hoping to avoid drilling any extra holes.
