Fitting extra leisure battery I6571 easy ? (1 Viewer)
JimboT
273
185
Welwyn Garden City
I'm a newbie
Ok we only have one leisure battery is it easy to fit another battery ?
And if so do i need to add another charger.
Does the battery need to be the same as one in there or can it be different AH?
jim
Nov 18, 2011
11,862
42,820
Planet Earth
A van
Over 25 year's
hi jim it isn't hard to fit spare leisure battery but where is your original bud
if you are going to use one of your looker or garage use the thickest wire you can get use good quality connections and just wire it up positive to positive negative to negative and you will have extra stored power I have three lesser battery's and a solar panel and never want for 12v now
it depends if you do a lot of off grid
I am sur that there will be someone along soon to advise you there are lodes who have done this
bill
11,862
42,820
Planet Earth
A van
Over 25 year's
jim
ok you must have upset someone I have never seen a post this neglected
TheBig1
17,605
43,102
Adding a second leisure battery is a simple case of finding a suitable spot as near the original as possible and connecting up as Bill said.
however it is best practice to make sure both batteries are the same age and condition, add a good new battery to an old tired one and it will not perform as well and if the old one fails it will kill the new one too.
you can mix amp/hour sizes and thats no huge problem as the charger will see just one large battery combined. always best to fit as powerful a battery as will fit the space
mounting the battery, always use a proper battery box and ventilate it to outside. a faulty battery produces gas which is explosive, so you dont want it in the van or anywhere near an ignition source. plastic boxes are a good move as less chances of anything falling on the terminals causing a short circuit.
many vans have the leisure battery under the drivers or passenger seat. this is not ideal for access or for venting. consider putting your extra battery in a locker.
your onboard charger or solar panels should be no problem charging the extra battery, it will just take longer to charge
JimboT
JimboT
273
185
Welwyn Garden City
I'm a newbie
thanks mines under the seat going to pull out and find what i have have been told its most likely a gel one.
Wasn't sure if the standard charger would charge two.
Will hopefully get some photos up to get ideas.
Jim
TheBig1
17,605
43,102
if it is a gel, you will need another gel because they need different charging regimes. if replacing both with SLA or AGM you will need to switch the charger to suit
43,304
49,294
if there is the slightest possibility the wire linking the batteries can be damaged then fit a fuse at BOTH ends of the link wire...close to the batteries.
a couple of 30a fuses will do the job.
even if very close its worth fitting one fuse as a precaution.
if the wire were to get damaged and short circuit to earth theres a real possibility of a fire without fuses.
Apr 27, 2008
11,842
14,068
Eastbourne East Sussex
Hymer low profile
Since 1972
Good advice but don't forget a 30A fuse is no good if you run an inverter, it will blow. 1000w inverter needs min 150A fuse and pro rata.
fozzyaj
Saltash Cornwall
Since 2009
Dethleffs i6571
Hi, I have the same van as you and have fitted a second leisure battery myself so can advise you on wiring and fuses etc.
If you let me have your email addresses I can discuss/ send you lots of info on your Dethleffs i6571.
Andy - fozzyaj@talktalk.net
JimboT
JimboT
273
185
Welwyn Garden City
I'm a newbie
Thanks some top information emailed
Jim
Jul 12, 2013
3,865
5,246
The City of Henlow
Adria Supreme
Since 1980
I am sorry to arrive so late on this question. I have the "T" 6571 Advantage with the two battery boxes under the passenger seat. The original single battery was a gel battery. I replaced it with a 110ah wet battery but I am now looking to find a second battery to fit in the limited height allowed for the second battery which is around 17.25cm high. Someone has kindly suggested a Varta LFD 90 but I was still hoping to get at least 100ah if possible, any ideas most welcome.
Alan
43,304
49,294
Cant help with the battery Alan, but have you reset your charger for wet batteries.
Gell have a different charging method to lead acids and you could boil it due to the sustained higher voltage needed for gell's.
