fitting additional water tank
Discussion in 'The Beginner' started by John H, Oct 8, 2009.
  1. John H
    John H Read Only Funster
    Sep 2, 2009
    254
    24
    Anglesey
    Were pretty new to motorhoming but have already realised we prefer to wildcamp than go on sites, however the good lady likes to use a lot of water and we run out after two days. can I just connect another water tank to the existing tank ? I have the room in a wardrobe and the fitting isnt a problem, I would like to know if its that simple or have I missed something ? I realise it will be extra weight etc but I'm happy enough with that.
    Regards, John
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,178
    16,639
    Liverpool.
    Hi,I had a similar problem as yourself, my solution was to take out the fresh water tank and fit a large poly tank under the bed. I take care not to run with it full though becouse of overweight and it does alter the handling somwhat.:Eeek:
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,261
    5,242
    East Sussex 01-580-881288
    Bit of a minefield that needs carefull consideration, how will you feed the water from the second tank into the first, especially if it is higher than the original.
    How do you fill the second one? and so on..............................
    Peter
  4. John H
    Sep 2, 2009
    254
    24
    Anglesey
    I dont think Ill have a problem with the tanks, as they have inspection hatches I can fit skin fittings and connect both tanks together, as for the position I have room to place the second tank in the wardrobe next to the original.If they are connected then the second tank should fill from the first as long as its also connected to the original tank at the top so it will vent. I was wondering if there was any reason not to do it ?
    regards, John
  5. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,690
    5,843
    Mansfield,Notts
    Yes it will work, you obviously understand the mechanics of it, and the only reasons not to do it would be other peoples prefrences, its what you want so go for it:thumb:
    The gauge should still function and be as acurate as it ever was, you will be drawing from both tanks at once, so when it says half, both tanks will be half:Wink:
    Geo
  6. John H
    Sep 2, 2009
    254
    24
    Anglesey
    That was my thinking Geo, I'd better get it done then to keep the good lady happy:RollEyes:
    Regards, John
  7. Geo
    Jul 29, 2007
    9,690
    5,843
    Mansfield,Notts
    Looking at your avatar you seem to have an affinity with water,
    Did you know a shark will only bite you when your wet:Eeek::Rofl1::Rofl1::Rofl1:
  8. John H
    Sep 2, 2009
    254
    24
    Anglesey
    Yes, I was diving with Great Whites in S Africa a few months ago, very impressive creatures, being in the water with them makes you feel very insignificant :Eeek:
    Regards, John
  9. Geo
    Jul 29, 2007
    9,690
    5,843
    Mansfield,Notts
    Thankfully they thought so too:Eeek::Rofl1:
