Fitting a SOG unit (type B). Can I remove the existing vent? (1 Viewer)
Biggerthanbefore
16
23
North Staffs
Since 1993, on and off.
Hi folks
As in the title I have purchased a SOG unit for my Niesmann Bischoff Arto 69E.
My question is: I have a small vent already in the cassette compartment door which has a pipe attached which I presume is an air vent already which links to the cassette pressure vent. The toilet is a Thetford c200 with electric flush which I believe is fed from the main tank.
I wondered if I would be able to do away with the existing vent and block up the hole in the door and use the SOG cover to hide the filled hole.
The blade opening mechanisim within the toilet compartment (the bit you cut off in the SOG instructions) has the rubber seal but my cassette has the non matching pressure relief valve which has me confused somewhat.
Thoughts anyone please?
Bodge
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Yep I agree sounds like Niesmann Bischoff own SOG..... never mind you can send it back or sell it on here(y)
Biggerthanbefore
Biggerthanbefore
16
23
North Staffs
Hi Lenny
The fitted vent is only small and no fan. It has a stainless steel shroud on the outside of the toilet casstte compartment door probably big enough to shove your thumb up. I think it links via a pipe to the rubber seal above the pressure relief valve on the cassette to vent the cassette when pressure builds up.
Jul 5, 2013
11,723
13,701
Since 2013
What toilet is it? The Thetford 250 and 260 has a vent that vents through the floor - opens when you slide the cassette in. As standard it does nothing, but you can buy a fan kit that fits in the floor complete with charcoal filter. Fan comes on with first press of the flush button.
Jan 22, 2013
1,252
60,081
London SE
A class Adria vision I707
since 1971
I also have the 250 thetford with the fan kit fitted but also fitted an additional fan downstream of the tank fan connected to a PIR,
every time you enter the loo the PIR switches on some low level LEDs and fan for about 5 mins,
it works great for those nocturnal visits without disturbing anybody,
Lenny HB
53,404
149,857
On the coast in West Sussex
Hymer B678 DL
The OP does say it is a C200 which does not have any vents.
Biggerthanbefore
Biggerthanbefore
16
23
North Staffs
Yes it is a c-200 cassette. The vent is original but I am going to have a look this week when I get over to my storage place.
thanks for the answers.
Jul 13, 2008
3,738
3,851
Low profile
My Burstner has a C200 with a black vent pipe fitted, I think I left it in situ when fitting the SOG.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
The C200 has an automatic pressure release vent (PRV) in the cassette which you remove and replace with the SOG pipe connector. In my Hymer, there was a black rubber corrugated tube that connected the PRV to the outside: it was vented through the floor, rather than the door. The connection with the PRV was effected by a rectangular rubber grommet. If I recall correctly, I simply left the black pipe in situ and bunged up the open end beneath the floor with a squirt of Sikaflex (probably overkill). I do not remember having to remove the other end of the pipe. So, in your case, I would have thought you can incorporate the existing hole in the door with the new SOG hole for its vent and suction motor.
Paul and Jeannette
86
51
lincoln, lincolnshire
coach
20 years on and off
We had a SOG fitted to our used motorhome by the suppliers. We had read that you do not need chemicals which seemed a good idea. However on collection the technician said that you still have to use chemicals, which rather defeats having it.
can anyone give the right answer please.
Lenny HB
53,404
149,857
Hymer B678 DL
Been using SOG's for 8 years never used any chemicals, link to SOG German site more info than on the UK one.
Mother Ship
440
991
Jersey
Pilote 626D
Since 1986
We've had a SOG for years and never used chemicals, that's why we fitted it so we didn't have to carry chemicals around. We are very pleased with it, no smells at all and all breaks down easy to empty out!
Jul 29, 2013
9,069
18,487
Salisbury
Hymer B678DL A class
since 2011
We don't use chemicals in ours works well wouldn't be without one.
Biggerthanbefore
Biggerthanbefore
16
23
North Staffs
Well, that's the Sog sorted. Here is a couple of photos of what I started with as described earlier in the thread.
The view inside the cassette door shows the black vent pipe.
the black vent pipe travels under the cassette docking area to an external vent.
The external vent.
The previous owner must have replaced the cassette as it has the incorrect vent to match up with the vent on the van (on pic one).
Anyway, 2 hours later I managed to lose the existing vent and hide the hole behind the new SOG vent. All working as it should do.
And the door sticker hides the cheeky hole left by the old vent. ;)
Discarded parts!!!!
JeanLuc
3,304
2,199
Warwickshire
Good job, you won't regret fitting a SOG. I suggest you buy spare charcoal filters when you are abroad - they are cheaper in Holland and Germany than in Britain.
Biggerthanbefore
Biggerthanbefore
16
23
North Staffs
Where do they sell them in Germany or Holland? Caravan/MH shops?
Lenny HB
53,404
149,857
Hymer B678 DL
You can buy online or list of dealers on their site SOG-Dahmann, most accessory shops stock them, but they may not have all versions in stock as there is quite a range now.
Quite impressed with the underfloor one we have in our van even though the filter cartridges are twice the price.
Jul 5, 2013
11,723
13,701
Since 2013
Lenny, is that the one that came as standard fit on your Hymer like mine? The one that comes on when you press the flush button for the first time? If so I think that is not made by the people who make the SOG, but is an optional extra fitted by Thetford that does the same thing. Had it on my previous motorhome (again standard fit) as well, and yes I agree it works well.
JeanLuc
3,304
2,199
Warwickshire
Yes - I have bought them in motorhome dealers for around €9 but I note that the UK distributor (Outdoor Bits) now sells them at £8 - a bit cheaper than they used to be I think.
JeanLuc
3,304
2,199
Warwickshire
Are you referring to this one?
Lenny HB
53,404
149,857
Hymer B678 DL
Yes, it is the SOG , the Thetford one is not quite the same that is the one that operates with the flush, The SOG operates with the blade (SOG have a patent on it).
Bought a new filter in Germany €24 they are £25 in the UK, kept the old one looking at refilling it.
GaryBDawson
12
16
Halifax
Cathago 142QB A Class
30years
Years ago I had a dog fitted to an Arto just as you have the ordinal pipe fitted by neisman did not do much, I never used chemicals. My current German van came with a factory fitted dog vented through the roof still no chemicals that is the idea.
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
You must be barking mad to fit one of those!:wink:
funflair
19,331
30,171
Guisborough
MORELO palace
since 2012
You can stay on the SOG (or should that be dog Gary) Stellplatz in Germany, it is just outside Coblenz on the Mosel.
Cycled past but not stayed.
Martin
