Fitting a hitch
Discussion in 'Fifth Wheelers' started by PaulJaq, Sep 20, 2012.
  1. PaulJaq
    PaulJaq Read Only Funster
    Sep 18, 2012
    28
    9
    Doncaster
    Hi,
    Me again!!
    Looking at fitting my own hitch.
    Haven't bought it yet and I'm sure they come with instructions - fix cetral side to side, fix into chassis via angle brackets of straight through etc.
    But one query is to comply with making the arrangement to suit artic or semi trailer regs where does the centre of the hitch pin have to be - exactly over the centre of the back axle, in front or behind the axle? I seen someone refer to 2 inchs but not sure if that was in front or behind.
    After looking at all the options I'm looking at extending the neck of the gooseneck - the bit that sticks out from the 5th wheeler, by using side plate extenders - seen it suggested as the second best option to a slider hitch which I don't really want.
    Cheers Paul
  2. vwalan
    vwalan Funster
    Sep 23, 2008
    7,800
    4,086
    roche cornwall
    on my vw it was just slightly in front of the rear axle . on my mitubishi its about two foot in front of the axle .
    all done to shut the gap between the cab and the trailer.
    i could have moved the pin back on the trailer but then the trailer wouldnt fit the vw .
    ideally a very short wheel base vehicle with the pin only just in front of the axle would be nice .
    i decided even if i did move the pin back it would have made a short trailer and might not have been so stable . the vw was a dream to reverse . shorter w,base etc . but we cope .
    hope that helps . carefull measurement required i find . get it wrong and cab clout is a problem . i can almost get mine into a situation where i can climb out the cab right on to the steps of the trailer . does screw the tyres abit . but it can be ideal in some places .
  3. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
    mine is slightly infront of my rear axle, and i have an extended pin box on mine
    Hi and welcome to Fun
    Maggie
  4. PaulJaq
    Sep 18, 2012
    28
    9
    Doncaster
    Thanks chatter
    Thanks for the info. thought it was about 50mm in front of the back axle but certainly no further back than on top of the axle.
    Looks like you have a Rodeo, does it pull ok? it it and auto?
    Cheers Paul
