Fitting a double DIN radio/sat nav (1 Viewer)
barrywi
120
28
Cumbria
C class
I am a Newbie to motorhomes but have caravaned for years
I have a 2008 Peugeot motorhome with the standard basic radio/CD player and am contemplating having a double size colour screen controlled radio/cd/ sat nav fitted. The well known makes cost an arm and a leg but there are several less known makes for sale on EBay. I fancy the XOMAX 2DTSBN6210 which is sold from Germany for around. £200 but would probably have it professionally installed.
Questions are:-
Is the space on the Peugeot big enough for a double din device?
Has anyone fitted a similar item and did they have any problems?
There is a video input to the screen for a reversing camera which my van has fitted so are the outputs from video cameras all the same ( composite video via the usual yellow phono plug).
Any other comments?
barrywi
barrywi
120
28
Cumbria
C class
The radio comes with a frame and trim so would not need to buy anything hopefully!
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The frame and trim will be to fit a double din standard opening, you don't have one.
barrywi
barrywi
120
28
Cumbria
C class
So the plate you sent a link for converts the Peugeot/ Fiat opening to the standard double din?
Nov 13, 2013
488
431
Bideford, Devon
Benimar Tessora 487
since 2011
Radio/sat Nav
Hi, I went down the 'arm and a leg' route and installed Pioneer, DAB radio and sat Nav with rear camera. It's great to have the unit in one piece installed and no leads etc everywhere. One thing and it's been mentioned before when Installed a separate power isolating switch was used, apparently some units still pull power when turned off!
Techno
Jul 28, 2010
15,475
20,756
May 2010
You even need the adapter for a single DIN unit as the fiat radio back then is not a DIN size. I upgraded to a DAB Kenwood from this pioneer
Techno
Jul 28, 2010
15,475
20,756
May 2010
Personally I think double DIN sat nav radios are in the wrong position for safe driving.
We use the 7" Chinese truck sat nav as far forward as possible, both me and the wife can see it clearly without looking down or sideways
barrywi
barrywi
120
28
Cumbria
C class
I am going to get some advice from a mobile fitter before deciding what to do. but any more suggestions will help and thanks to those who have already given advice
