Fitted my LPG today.
Discussion in 'Motorhome Chat' started by lorger, Feb 15, 2016.
  1. lorger
    lorger Funster
    Jul 11, 2008
    6,407
    7,856
    Dumfries
    Since it was a nice sunny day I thought I'd tackle the job of the refillable gas system, must say its a bit daunting drilling a hole in your brand new van I always remember though cut twice measure once or something like that.
    Firstly stripped down the inside to make sure no cables or support beans in the way, the only small issue was the gas pipe prevents me from getting the filler at the exact same hight as the other two the fact they're not close to each other means it doesn't look out of place.
    Spirit level through window so I can be sure my measurement is same inside as out.
    Tape up and marked to save scratching or slipping.
    Hole cut and wee lug holes cut top and bottom
    Could get them the exact same hight due to internal gas pipe.
    Birdseye view pipe comes into van in different locker then filler pipe runs along back of unit and inside of van before coming out at gas locker.
    • Like it Like it x 13
    • Informative Informative x 3
  2. JJ
    JJ Funster
    May 1, 2008
    15,027
    27,038
    Cripes...
    You should have paid a slave to do that for you while you went off for a round of golf!
    JJ :cool:
    • Like it Like it x 2
  3. lorger
    lorger Funster
    Jul 11, 2008
    6,407
    7,856
    Dumfries
    With the money I've saved in paying the slave I can afford two rounds now :D
    • Funny Funny x 3
  4. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    Gerry i very am disappointed .... your van is "DIRTY"!;)
    • Funny Funny x 2
  5. lorger
    lorger Funster
    Jul 11, 2008
    6,407
    7,856
    Dumfries
    I know that's the next job on the list, not this week though as off skiing Wednesday so will get it washed when back.
  6. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    6,055
    9,377
    Wrenthorpe, Wakefield.
    Very bum squeaky moment isn't it Gerry ....cutting into a brand new van ?!
    But at least you've got it over with now ! (y)
  7. lorger
    lorger Funster
    Jul 11, 2008
    6,407
    7,856
    Dumfries
    It certainly is, I think if i did a van like yours i would take about 2 years as I must have measured and measured it. It actually took me all morning to measure and 2 seconds to drill.
    A bit like sex really all morning to think about it then its over before you know :D:D
    • Like it Like it x 3
    • Funny Funny x 3
  8. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,605
    12,024
    E Yorks
    That's bad enough ... you want to try drilling a hole through the roof of a PVC for a solar panel cable ... it's NOT easy to work out exactly where it needs to go due to all the curves and insulation etc ... now that was MORE than a bit 'bum squeaky'!!!! o_O
  9. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    Could have drilled hole though floor and fitted on L bracket on sill...
  10. campa cola
    campa cola Funster
    Oct 5, 2012
    3,084
    5,969
    Weegeland
    The only extra hole I drilled on mine was on the aluminium skirt and that was bum squeaky enough (y) I used part of one of the two existing vents to put the pipe through to the gas cupboard and frankly don't care of its not approved of. The less holes drilled the better IMHO.
  11. lorger
    lorger Funster
    Jul 11, 2008
    6,407
    7,856
    Dumfries
    Im doing a Satellite dish nest so might be a bit more scary, need to watch out for cross members i suppose.
  12. lorger
    lorger Funster
    Jul 11, 2008
    6,407
    7,856
    Dumfries
    I could have but prefer this way.
  13. Minxy Girl
    Aug 22, 2007
    10,605
    12,024
    E Yorks
    lorger - only one thing to do now IMV - put some pipe lagging round the gas inlet pipe where it comes through the cupboard back to avoid it chaffing in transit and maybe a secure it to the back panel about midway so that it can't 'waggle' up and down.
  14. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,224
    15,205
    Leeds the one up North
    I like holes, try drilling an oblong (y)
    [​IMG]
    • Funny Funny x 1
  15. Minxy Girl
    Aug 22, 2007
    10,605
    12,024
    E Yorks
    Oh yes! I once had to drill a large hole to put a 'through the roof' telescopic aerial on our then Rapido ... lots of pushing and 'feeling' for resistance on the ceiling to try to work out where the struts were and then measured up and transferred my findings to the roof ... that was the easy bit! I started to make the large hole from the outside (ie on the roof) and I took it very slowly and kept stopping and examining the hole which was a good thing as right where I was drilling they had, for some unknown reason, run electric cable for lights even though there were none in the vicinity and it wasn't an obvious 'cable' run area!!! Once the small end of the hole cutter had gone through and I'd moved the cables out of harms way, I then finished cutting from the inside in order to get a neat finish.
    So ... watch out for struts AND cables!!!!!
  16. gillnphil
    gillnphil Funster
    Apr 12, 2010
    973
    4,714
    West Suffolk
    Nice work. I have done two LPG systems and it gets easier.
    Phil
  17. Badknee
    Badknee Funster
    Aug 25, 2014
    3,840
    17,235
    notloB
    image.jpg image.jpg I didn't do ours, I got youngest son to do it so if he buggered it up I could have blamed him. (y);)
