First time "off grid" (1 Viewer)
Gollom
206
122
Preston, Lancs
Hymer B534 (1994) - Hetty
Since 2014
Sue and I are going to the Southport meet in June (sounds like it will be a total blast!) from Friday lunchtime to Sunday lunchtime. This will be our first time without hook-up so:
  • Using just lights and water pump (the fridge, water heater and heating - if needed - will be on gas of course), how long can we expect our leisure battery to last?
  • I hear that we must not let the leisure battery discharge below 50% - is this critical?
  • Would the power sockets work? If so, how much does a 22" LED TV draw?
  • Should I run the engine at some stage? (I assume that will top up the leisure battery a bit?)
  • Anything I have not anticipated?
Many thanks
Steve & Sue
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
The 12v power sockets will work but not the 240V ones unless you have an inverter fitted and even then not advised without a means of recharging. Once a battery discharges below 50% it starts to sulphate and lasting damage is done how much depends on how low you take it and how long before it receives a charge. if your heater is blown air then it will use a fair bit otherwise just gas. We just use the gas and don't switch the blowers on at all. Should be minimal lights at that time of the year. If it is a 12v TV could be anything from 4-6amps per hour if 240V via an inverter a little more. But the funsters will keep you locked up in the hospitality tent and be forcing drink down you until the early hours so no problem there either. You should be fine. Sa for running the engine unless you have a B2B charger you will use more power from the engine battery to start it than you can put back an an hour or two.
Solar is KING
Lenny HB
53,417
149,915
On the coast in West Sussex
Hymer B678 DL
Running diesel engines at idle while stationary is not good for them & it will annoy all your neighbors & it won't put much charge into your battery unless you intend to leave it running for 6 -10 hours.
Assuming your battery is in good condition and fully charged two nights will not be a problem.
Dave K
1,311
2,477
Somerset
Pilote P740C
Since 2013
Solar is KING
I think I'll be looking into solar, any recommendations from where to buy and are they a DIY fit or a specialist job
Dave
Bluestar
279
164
Brighton
Class
10 years.. On and Off
Can be DIY but worth doing lots of reading on the subject and match the system to what you want, plus what you want to spend.. :)
RowleyBirkinQC
2,347
226,688
Dazed & Confused
Dave
If you are in Somerset I guess Vanbitz would be a good starting point for having Solar supplied and fitted, they have a forum discount I believe...
1,023
5,392
Gloucester
Self-converted Van
Since 2014
Dave
We only started motorhoming in September and going off hookup was a major worry for us, continually worrying about running out of power. We looked into doing a DIY fit solar panel and extra battery, but had such a good price from Vanbitz decided to go there. I know hubby could fit it, but so much less stressful to let a professional do it and know you have the peace of mind of warranty. Our motorhome is our pride and joy and I certainly felt happier! Fabulous job done by Vanbitz, now so much more relaxed off hookup! Best thing we've done so far. Definitely recommend! (y)
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
fitting solar is a very straight forward diy job you just need to chose a route for getting from panel to controller and from controller to battery ,usual place is down through a wardrobe panel is glued to roof and one hole drilled down to take the cables
Dave K
1,311
2,477
Somerset
Pilote P740C
Since 2013
Thanks Gerri, always good to hear recommendations
Gollom
Gollom
206
122
Preston, Lancs
Since 2014
Can I be so bold to ask what are we talking about in terms of price? Even ballpark is fine - low, mid or high hundreds?
Dave K
1,311
2,477
Somerset
Pilote P740C
Since 2013
I've just looked on vanbitz website, £549 for 100w panel supplied and fitted
1,023
5,392
Gloucester
Self-converted Van
Since 2014
As per the price list on Vanbitz website, we had the 100w solar panel, battery master (sorts out topping up vehicle/leisure batteries) and an extra leisure battery fitted. As a Fun member you also get 10% discount, and a free night staying at their fabulous campsite! We were given a courtesy lift into Taunton to sightsee whilst the job was done. All in all top service!
Bertie Bassett
2,743
8,702
since 1988
Seconded again!(y)
361
225
Reading & Surgeres France.
Hymer 584
Motor homing since 1998.
I'd second or third solar panels but you didn't say in your original post what battery you had or if you have LED lighting. If you don't have a TV you could be ok for quite a few days.
We have an 85 amp gel battery & 160 watts of solar. run for weeks without EHU.
Barrie.
Cal54
3,805
61,996
Southport, UK
Leisuredrive Renoir
Since 1996
Dave Newell, another Funster member fit my 100 wt solar at a Warners outdoor show. The cost was just over £500 and a great job.
