firmware upgrade for alfa AWUS036NH (1 Viewer)
TheBig1
17,591
42,992
Hi All trying to install the firmware upgrade but can't get laptop to connect to [HI]192.168.2.1.[/HI]
Anyone any ideas?
cheers
David:Smile:
have you tried 192.168.1.1 as the address? as far as i remember that is the default address for the adapter
D
Dai Motorhome
151
19
Burnham on Sea, Somerset
a class
tried 192.168.1.1 but no luck. maybe I have the correct firmware, but stuck untiol i can get into the awu
cheers
David
D
Dai Motorhome
151
19
a class
I think I'm getting myself and everyone confused! I think the firmware upgrade will be for my alpha r36 router not the signal booster!
I ve got the booster to connect to the broadband , but when I open a browser it tells me no network!!
Any ideas welcomed!
David
mid4did
526
727
N.somerset
Hymer Tramp R 655 GT
started in a minivan 1970's when I could fit into it.
I take it you are doing the upgrade from the same device that this is plugged into?
If so just to check go to a command prompt and run ipconfig check the gateway address it should be the default of 192.168.2.1 if not use the gateway shown in the ipconfig output in a web browser and access the gui.
It is recommended to set a static ip address but I think its not necessary if you,ve got one when you do the above command.If you still cant connect to the gui try ipconfig /release then ipconfig /renew then ipconfig to see that you,ve got an ip address.Good luck
