Firewire question / problem
Discussion in 'Computers' started by scotjimland, Feb 17, 2012.
  1. scotjimland
    Jul 25, 2007
    28,934
    25,601
    I have an Sony 8 mm cam-corder and a stack of 8mm tapes I want to copy to DVD .. The camera has a firewire port.
    I used to transfer onto the Mac.. (it had a firewire port).. but sadly it has gone belly up and not economical to repair ...
    The Dell has USB and an eSata port .. but no firewire :Doh:
    I've been Googling but as yet not found an easy way of doing it.. to be honest I don't think there is one ...
    Any suggestions apart from throwing in the towel ..
  2. pablomc
    pablomc Funster Life Member
    Apr 20, 2010
    860
    235
    Durham
    If your laptop has a PCMCIA slot or express slot you can buy a firewire card for it.
  3. scotjimland
    Jul 25, 2007
    28,934
    25,601
    err.. just checked.. I don't have either slots ...
  4. Glynn
    Glynn Read Only Funster
    May 2, 2010
    163
    18
    Lancashire
    Buy another Mac !.
  5. scotjimland
    Jul 25, 2007
    28,934
    25,601
    never again..
    • Like Like x 1
  6. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    You must surely have at least one spare slot.
    If so, I've got a Firewire card I can lend you.
  7. pablomc
    Apr 20, 2010
    860
    235
    Durham
    USB to Express card adaptor.
    [ame="http://www.amazon.co.uk/Startech-Usb-Express-Card-Adapter/dp/B0024OMS6E/ref=sr_1_8?ie=UTF8&qid=1329515218&sr=8-8"]USB to Express card adaptor[/ame]
  8. Pikey Pete
    Pikey Pete Read Only Funster
    May 25, 2008
    1,532
    1,141
    o
  9. Onderweg
    Onderweg Funster
    Jul 17, 2008
    511
    240
    Vlissingen, Holland
    I think your only option would be a firewire to usb adaptor.
    FireWire is, depending on the type between 400 (6 pins) and 800 mpbs (9 pins)
    But be careful, if your laptop has
    USB 1.1 --> dont even try only 12 mbps,
    USB 2.0 --> 480 mbps, could work but carefully check whether video transmission is supported (effective speed is often only 240)
    USB 3.0 --> 5.000 mbps was promised. You can recognize Usb3 very easy, there is something blue in the connector (but in 2010 the effective speed was 400-420 mbps, sorry i am retired so dont have the new facts :RollEyes:) but USB3.0 will certainly do the trick
    Only few laptops have an USB3.0 connection :cry:
    Hope this is of some help
    Regards
    Paul and Ineke
  10. scotjimland
    Jul 25, 2007
    28,934
    25,601
    If you mean Express or PCMCIA slot.. no.. thanks for your offer
    I have 3 x usb2 , 1x eSata socket , I x HDMI socket and a card reader slot
    thanks, I had a look at these but can't determine if it would work ..
    thanks Pete .. I honestly don't know
    thanks for the info..
    will do some more reading on it ..
  11. Diabalo
    Diabalo Funster
    Oct 14, 2007
    1,986
    386
    Rochester
    You can get USB to Firewire adapters off fleabay for £2
  12. philw111
    philw111 Funster
    Mar 22, 2009
    606
    515
    Moray Firth
    I have transferred 8mm video to digital using an "EasyCap USB video grabber". It has standard connections to the video camera at one end and a USB at the other - quality seems fine (as long as you aren't expecting HD).
    The cables are on eBay for about a fiver - just search for EasyCap.
    Phil
  13. scotjimland
    Jul 25, 2007
    28,934
    25,601
    That looks interesting .. thanks Phil.. will look into this idea.. for £8 I'll give it a punt and see how it goes..
    Re USB/Firewire adapters, there seems to be a lot of conflicting advice on the AV forums .. this is from a 'senior' member..
  14. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    hi Jim I have a firewire card and software new in box for £8 if of any use.
  15. scotjimland
    Jul 25, 2007
    28,934
    25,601
    thanks Roger .. but no slot to fit a firewire card on the lappy
  16. wivvy's dad
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    You didn't say at the start that it was a laptop..... :Doh:
  17. scotjimland
    Jul 25, 2007
    28,934
    25,601
    EasyCap arrived yesterday..
    [​IMG]
    I played with it yesterday and the only problem I have is sound quality .. it sounds like a badly tuned AM radio .. :Doh:
    Did a bit of Googling and found several others had the same issue, the workaround is to use the lappy's Microphone jack socket connected directly to the CamCorder's (white) RCA socket..
    After doing this it worked a treat .. can also use it just to view on the TV using the laptop HDMI output ..
    I have video going back to the mid 90s.. so we spend several hours just re living the kids growing up, holidays in France and Spain.. great memories captured for ever on tape.. :Smile:
    Now the big task... copying, editing and putting onto DVD ...
    The ULead video editing software supplied looks ok.. if a bid dated.. but it runs ok on Windows7, haven't had a real play with it yet .. too busy viewing ..
    • Like Like x 1
