Fired the solar up-what next?
Discussion in 'Motorhome Chat' started by ultima, Aug 7, 2016.
  1. ultima
    ultima Funster
    Mar 24, 2010
    223
    83
    stoke on trent
    Just fitted a 80w panel and cheap PWM controller and pleased with results-was getting around 5 a and fully charged batteries (2x110a) comfortably.Now I wont be using the van for a bit so do I pull fuse out to panel to stop it charging or just leave it connected permanently?
  2. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    Leave it.
    • Like it Like it x 1
  3. Speve
    Speve Funster
    Jul 29, 2013
    2,282
    2,200
    Salisbury
    Leave it connected it will keep your batteries topped up when not in use as long as they are in the sun.
  4. DBK
    DBK Funster
    Jan 9, 2013
    9,209
    12,821
    Plympton, Devon
    If you add a Battery Master from Van Bitz it will keep the vehicle battery charged up as well.
  5. TerryL
    TerryL Funster Life Member
    Mar 5, 2010
    1,489
    1,467
    North East
    5 amps is pretty good from an 80 watt panel.
    Second the Battery Master recommendation - your vehicle battery will discharge gradually and on a modern M/H there's always something taking a tiny amount of juice.
  6. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,408
    716
    Would say 5 amps is "very" good for an 80watt panel. ;)
  7. ultima
    ultima Funster
    Mar 24, 2010
    223
    83
    stoke on trent
    May fit a better (MPPT) dual battery regulator later to replace the cheap PWM.The 5 amps was only when in direct sun-not all day.
  8. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    2,022
    1,753
    Bungay Suffolk
    Job done, now just enjoy it !!
    Mitch.
