Finlux 22 Hd Led Dvd Combi
Discussion in 'TV & Satellite' started by DurhamSpartan, Jun 15, 2015.
  1. DurhamSpartan
    DurhamSpartan Read Only Funster
    Feb 16, 2015
    7
    4
    Blyth, Northumberland
    I bought one of these and have had 'mixed' success with recording to the USB. Sometimes it records as I think it should and at other times it does nothing. I have used the EPG to select a programme to record, I have then ensured the correct channel is selected and put the TV onto stand by mode. At first this seemed to work fine but recently it has failed to record, more than it has done. I contacted Finlux where you are obliged to use 'live chat' after nearly 2 hours of live chat and 3 separate chats Finlux position is now:-
    'You can record from a Finlux TV while the actual programme you wish to record is at that time being broadcast from a TV which is switched on and playing, and you can also set a timer to record future programmes but the TV must be on and playing that channel'
    This to me is crazy, I expect to be able to record when I am not watching the TV, when I am out, in bed etc.
    Does anyone else have a similar TV and if so how do they record to the USB?
  2. Baycott
    Baycott Funster
    Nov 6, 2013
    6,458
    13,022
    East Sussex
    We have exactly the same TV but the 19in version.
    We do exactly as you describe and it has not failed to record.
    Oh Dear, perhaps I shouldn't have said that :whistle::whistle:
    Perhaps there is a fault. Is it still in warranty?
  3. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Same here on the 19".
    Trikeman.
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,187
    15,162
    Leeds the one up North
    The USB is powered by the TV. If the TV is turned off it cannot record.
    EDIT should work on standby What does your user manual say?
  5. DurhamSpartan
    Feb 16, 2015
    7
    4
    It is still under warranty and someone from Finlux is meant to ring me tomorrow, so the fact that others are recording as we were will be my staring point. Finlux 'live chat' could not explain to me why it had stopped recording. I appreciate that if the TV is turned off at the plug then the USB will not be powered but I always leave it in standby mode - a red light remains on the TV on the front. Thanks for the responses so far.
    John W
    • Like it Like it x 1
  6. Langtoftlad
    Langtoftlad Funster Life Member
    Apr 12, 2011
    1,941
    4,961
    Langtoft, South Lincs
    I would say that it's a TV with a recording facility.... It's not a fully functional PVR.
    So probably useful if you're watching something, then have to go out etc.
    I guess Finlux don't sell it as having timer recording.
    I think mine is brilliant, cheap as chips, miserly power consumption, good picture, multi region DVD player AND some recording capabilities - all for under £150
  7. Techno
    Jul 28, 2010
    14,187
    15,162
    Quickly reading an online user manual it does say that the USB device must be plugged in when the TV is turned off to enable it. If you plug yours in and out for other uses this may be the problem?
    • To record a programme, you should first connect a USB disk to your TV while the TV is switched off. You should then switch on the TV to enable
      recording feature. Otherwise, recording feature will not be available.
  8. Langtoftlad
    Apr 12, 2011
    1,941
    4,961
    I also presume the electronics & software are El cheapo Chinese - so the difference between one model & another, or even between two instances of the same model could be down to slight variations in either components or firmware.
    I've found quite often that the 'manufacturers' or retailers are often unaware of some of the features these microchip possess.
  9. Langtoftlad
    Apr 12, 2011
    1,941
    4,961
    Is your USB formatted to use by the TV?
  10. DurhamSpartan
    Feb 16, 2015
    7
    4
    Yes it is. It worked perfectly and I have recorded over 15 hours. Now it will no longer record as it did previously. It is only in the last week that it stopped recording as it did and I think it should do.
  11. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,190
    3,014
    Kendal, Cumbria
    Try re-formatting the USB stick or try a different one. It's not unknown for them to become corrupted (for no obvious reason).
  12. DurhamSpartan
    Feb 16, 2015
    7
    4
    Well I should have remembered earlier the advice I always got from the IT department at work. So I switched the TV off at the wall removed the USB for a few minutes reinstalled and switched on. Programmed it to start recording at 7pm and it did! Let's hope it continues to work. Thanks to all for your helpful posts most appreciated.
  13. Techno
    Jul 28, 2010
    14,187
    15,162
    Exactly as I said earlier
