Filling water tank
Discussion in 'The Beginner' started by Tony H, Apr 1, 2015.
  1. Tony H
    Tony H Read Only Funster
    Mar 28, 2015
    27
    3
    Leicestershire
    Hi,
    When filling my new Motorhome via the whale attachment how do you no it's full? The manual says when full it will come out the overflow, which it did but very slowly. It was as though the tank came under pressure and slowed the flow down then forced the water out through the overflow underneath the van.
    I also no you can look at the gauge in the van, but if you're one your own this is not possible unless you turned tap off first.
    Long winded question I no but does this sound normal?
  2. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    I just wait till it comes out the overflow ( that's what the manual say) going to extend the overflow tube to reach the side of the van to save sending down ( one of these fine days)
  3. normanandsue
    normanandsue Funster
    Dec 31, 2010
    1,325
    4,551
    Dunfermline - Scotland
    On my whale system the pump cuts out when the tank is full; plus I check the level on the gauge in the van though it is only a guide.
  4. camocam1
    Aug 28, 2012
    1,112
    783
    Ours does but only if using an aqua roll and not with a hose
  5. bertiebasset
    bertiebasset Funster
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    Our pump just keeps going but the overflow has been sited to the side of the van nearby so easily seen/heard. (y)
  6. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,090
    2,931
    Kendal, Cumbria
    Yes
  7. WillH
    WillH Funster
    Feb 9, 2008
    1,724
    1,436
    SW Scotland
    I use my faithful watering can.....
  8. rosalan
    rosalan Funster
    Jul 12, 2013
    881
    759
    Beds
    Another watering can man.
    Filling up at home I rarely do, for the extra weight I like to avoid.
    The gauge on my van really only shows 1/4, 1/2, 3/4 or full so not very accurate. I tend to drive with 1/2 full and fill up when I get somewhere. However in the winter and in France I may well try to keep the tank full, for frozen taps or taps turned off are common.
    Alan
    • Thanks Thanks x 1
