filling water heater
Discussion in 'The Beginner' started by jgee, Jan 27, 2010.
  1. jgee
    jgee Read Only Funster
    Dec 21, 2009
    85
    wigan
    during the cold spell i drained the water and waste tanks and the water heater my problem is how do i refill the water heater. is it acase of attaching water hose to side of van and let it fill up.do ineed electric supply to van whilst this is going on. how do i know when water heater etc is full of water.this is the first time for me new to moterhome. should i have taken fuse out to water heater when draing down:Sad:
  2. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    I suppose that someone who has the same mh as you will confirm/deny this but it should fill when you fill your freshwater tank.
    Jim
    :Smile:
    Edit: Run your pump after you have filled the fresh water tank.
  3. kinsleyboy
    kinsleyboy Read Only Funster
    Dec 11, 2009
    115
    15
    Shropshire
    I'm new to motorhoming too & I drained my heater.
    I refilled it okay the other day by putting water into the freshwater tank, switch on power to taps, open taps in "hot " position and this should draw water into the heater, they'll gurgle away while the air is pushed out of the pipes.
    When the gurgling stops, you should be okay. I was and the heater worked a dream .
    Good luck.:thumb:
  4. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,479
    2,594
    UK / Spain
    Hi, I take it you have a Carver Cascade 2 water heater and you removed the plastic plug on the outside of the heater.:Smile: If so just refill your water tank and with pump ON and the hot taps open one at a time, I always started with the sink and finished at the shower, just a chase of getting all the air out, when the pump is on and air in the system it will spit once it has stopped spitting job done...........:BigGrin:
    If you have a Truma heater and had to push the plunger switch down to drain it pull it back up and put a peg on it to hold it up untill the system is full and free of air.:Smile: Bob
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,946
    17,609
    YO11 2BD
    same reply as the others but in addition.....after the hot is bled through do the same with the cold taps or, when you do need cold water, you may get a soaking as it purges through the system.
    if the toilet uses the main water tank then do the same there.
    if it has its own supply then no need.
    clean flow with no bubbles...job done.
  6. dellwood33
    dellwood33 Read Only Funster
    Apr 25, 2009
    3,449
    887
    Newcastle
    I hope the reason for refilling the system is because you are going to use the motorhome ?
    I wouldn't rely on the present mild spell continuing into spring and your water system will still be at risk from frosts etc . :Smile:
  7. johngee
    johngee Read Only Funster
    Aug 19, 2009
    59
    Hampshire, UK
    Attach the hose to the socket on the van.
    Fill the tank.
    Start the pump.
    Turn on the tap in the kitchen for both hot & cold.
    Wait fot the spluttering to stop.
    Turn off the tap.
    No mains electricity required
