Filling on board water tank
Discussion in 'The Beginner' started by paul18, Mar 1, 2015.
  1. paul18
    paul18
    Dec 16, 2014
    172
    34
    Somerset
    Going away first time for a week in a while, but wont arrive first night until after dark. Should we fill on board water tank before we leave, or wait until we get there? Disadvantages and advantages to both I guess, but what are they please?
  2. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,181
    14,113
    Bolsover, Derbyshire
    it will
    Increase payload
    save time and hassle on arrival
    it might
    affect handling
    reduce mpg
    it wont
    matter whichever you do, payload excepted
    • Like it Like it x 2
  3. Abacist
    Abacist Funster
    Oct 15, 2013
    1,308
    1,563
    Devon
    Depends where you are going! Do you know what to expect at the other end? Just been to a CL and had to fill the whole tank with the watering can as the tap was way too far away to fill with the hose! Weight of water will add to weight of van for travel and increase fuel consumption. Perhaps part fill as a compromise so you can use the loo and make drinks on your journey and have some left at the other end to get you started.
  4. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,372
    1,458
    Suffolk
    If you can carry the weight---might as well fill up------if the weight is pushing a bit just put in 1/4 --1/2 a tank-----you only really need enough for the loo and food at night and TEA in the morning
    Nigel & Pamala
    • Like it Like it x 1
  5. nifty fifty
    nifty fifty Funster
    Sep 29, 2009
    141
    29
    norwich
    put 10>15ltres in tank befor leaving fill up next day in daylight all problems covered
  6. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,987
    12,161
    Kettering
    If you are going somewhere where you know you can fill up, a site for example, then I would travel with a few litres, enough to fill the kettle a couple of times and do the washing up and then fill up properly when you get there, especially if you're arriving at night. Fill it in the morning after a brew (y) The only times we've ever travelled full up is when we've known there wouldn't be any available at the destination.
  7. paul18
    paul18
    Dec 16, 2014
    172
    34
    Somerset
    How much is it likely to effect handling?
  8. Hotelman
    Hotelman Funster
    Oct 12, 2013
    358
    410
    Filey
    I think just fill up, it will affect the mpg a little, and I don't think you'll notice a difference in the handling, remember that's why you have a tank...
    No worrying, no stress, no grief, just fill up .....
    Have a great trip.....
    • Like it Like it x 3
  9. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,181
    14,113
    another important thought, it depends on what you use the water for
    we don't drink or cook with ours, but need it for toilet flush and washing (us and pots)
    we have plenty of payload so I drive with mine full from home, or when moving on from a site, only leaving empty when going home
    Handling, really cant say I have noticed anything, you might presume it would be worse if only half full, a lot will depend on how big your tank is and how heavy your MH is
  10. paul18
    paul18
    Dec 16, 2014
    172
    34
    Somerset
    Forgive my ignorance, but can you explain what you mean by if you can carry the eeight?
  11. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,623
    2,192
    Rutland
    Convenience ,do it before you go you don't want to be pissing about in the dark when you arrive !
    Wherever we go I always run with full tanks even on long runs .The only problem I could see is if you are close to your weight limit before you fill up ,a full tank may tip you over.
    If anything goes wrong en route or you change your plans,a full tank means your self sufficient .A full tank won't make any difference to handling .The extra fuel used ain't worth worrying about,.unless your the type of person who drives at 50 ,won't use the aircon and travels in a lorries slipstream to save a few pennies!
    Vlad
    Vlad
    • Like it Like it x 7
  12. NickNic
    Jan 14, 2014
    5,987
    12,161
    Kettering
    A litre of water weighs 1kg. So a full tank is 100 - 120kg. On a lot of motorhomes that will be more than enough to tip you over your maximum permitted weight - 3500kg or whatever.
  13. paul18
    paul18
    Dec 16, 2014
    172
    34
    Somerset
    How do you know your permitted and actual weight without going to a weigh station?
  14. Stephen & Jeannie
    Stephen & Jeannie Read Only Funster
    Aug 27, 2008
    4,198
    3,262
    Gobowen near Oswestry !!
    A happy van has a full water tank and an empty shitter !
    For the amount you spent on the van, why bother with minutiae!
    :active::active::active:
    • Like it Like it x 11
  15. NickNic
    Jan 14, 2014
    5,987
    12,161
    Kettering
    Your permitted will be on a weight plate on the vehicle somewhere, or failing that on your V5. For your actual weight you need to load up as you would if going away and go to a weigh bridge. Your manufactuer will quote a "mass in running order" figure but they all lie so it's worthless.
  16. denisejoe
    denisejoe Funster Life Member
    Aug 6, 2014
    1,332
    944
    Isle of Sheppy
    We use our water for every thing and depending on the size of the tank how full would you need ours is about 120 lts so 70%would do us for a week end
    Joe
  17. paul18
    paul18
    Dec 16, 2014
    172
    34
    Somerset
    I have looked for a weight plate, and can find nothing, also couldnt see it on V5. Used to caravans where its usually by door
  18. vin0114
    vin0114 Funster
    Feb 8, 2014
    789
    795
    Sheffield
    the W is next to the E so eight should read weight:)
    We take just enough for emergencies only and take separate 20 ltrs fresh water for drinks/food.
  19. NickNic
    Jan 14, 2014
    5,987
    12,161
    Kettering
    on your V5 its "Revenue Weight" in section 4 about a third of the way down.
  20. paul18
    paul18
    Dec 16, 2014
    172
    34
    Somerset
    Revenue weight is blank on the V5
