fibreglass body deterioration
Discussion in 'Motorhome Chat' started by Chizz and Jax, Jan 22, 2015.
  1. Chizz and Jax
    Chizz and Jax Read Only Funster
    Mar 27, 2014
    3
    Staffordshire
    Hope someone can help me with this one. My eura mobil motor home is made of fibreglass and whilst cleaning it noticed a few patches where it was chalky and matt. Did a bit of research and sounds like it could be oxidation where the gel coat has been lost?
    Also to further worries on closer inspection the surface where this has occurred is peppered in black spots. Anybody out there know off this condition? Or experienced the same.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,903
    17,577
    YO11 2BD
    Could be wrong but im sure i read somewhere the black spots are fungal growths/spores.
    A bit of bleach will kill it if it is, then the gell coat needs urgent repair.
    • Like Like x 2
  3. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,849
    1,907
    Warwickshire
    • Like Like x 3
  4. scotjimland
    Jul 25, 2007
    28,934
    25,601
    If it needs more than just a clean and polish, I would suggest you visit a boatyard or boat builder and ask for professional advice.. they are usually very knowledgeable and helpful with fiberglass issues.. and usually stock products if you need to do a repair ... they may also offer to do the work if your not happy about tackling yourself.
    • Like Like x 2
  5. WAG2CRU
    WAG2CRU Read Only Funster
    May 31, 2012
    378
    496
    Argyll
    Sounds like the gel coat may have aeration ie small bubbles are formed within the gel coat as it sets, once the surface deteriorates with age, wear and uv degradation, small pin holes appear on the surface. The black spots may well be fungal growth within these pin holes. Firstly, unless very matted, avoid using any abrasive polish, it will only make the situation worse. Clean the gel coat with a surface biocide not bleach or a bleaching agent. Polycel mould killer will do the trick and is easily available. Leave the biocide on for a couple of dry days then wash thoroughly with plenty of water to remove the dead fungus. Once dry, seal with Polytrol which is available from good Yacht Chandlers. Repeat as necessary, this is not a permanent repair but, the only real alternative would be to re gel coat, paint or wrap.
    • Like Like x 3
  6. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,576
    5,654
    Near Mold North Wales
    Do you have post any pictures of the fibreglass?
  7. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    How old is the van?
  8. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,091
    5,372
    Guisborough
    I would give it a good polish with the Farecla gel coat restorer and wax first, I dont see why the Gel coat would have any air bubbles in as it is specifically formulated to cure without being porous.
