Fiat wheels......change from 15inch to 16 inch? (1 Viewer)
C
Chockswahay
Whilst researching new tyres for my van I have been advised that the 15inch wheels are 'out dated' and that more choice is available for 16 inch wheels.
Has anyone ever changed their wheels from 15 to 16 ? Any reasons why it can not be done? After all the Fiat is the same as the Peugeot and Citroen and they have 16 inch wheels.
Also (if the price is right) I could then consider a 'summer' set and a 'winter' set.........
With all this in mind what size tyres are fitted to the 16 inch wheels on Peugeot or Citroen based motorhomes?
Cheers (y)
Sep 10, 2013
1,187
18,697
Chelmsford Essex
Getting better
I know nowt about Fiat/Citroen wheels and tyres etc. but generally when changing wheels and tyre sizes you need to be aware of the changes needed to your speedo & odometer and your insurances.
No doubt someone will be along soon with the full sp on Fiat etc.
Aug 29, 2010
845
1,246
Nuneaton. Only when I have to.
Hymer Exsis t564
Since Sept 2010
Interesting question which had also occurred to me. My van is on the Alco 'light' chassis which seems to have 15" wheels as standard. However the same model on the 'heavy' version of the chassis has 16", perhaps to accommodate tyres with a higher load rating for the increased GVW.
Jan 27, 2009
872
3,358
Leyland Lancs
since 2001
Try S.V. Tech (Leyland) 01772 621800 they should have the answers for technical/mechanical vehicle up-grades.
I have found them very helpful.
Reactions: JJ
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
If it is anything like our Fiat it will probably make the speedo nearer to accurate, it is so far out I have always thought it should have 16" wheels on and there is lots of wheel arch space to accommodate them.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
15's have a 118 bolt circle for one thing
16's are 130
Yes it is all about load, 16" tyres have a higher load index rating
Brakes are probably beefier too
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Hi on the last van the 5th gear ration was /or seemed to be wrong Halden Hill 5th gear 1/2 loaded!(was like driving in 4th everywhere.)
so after exploring various options ,getting correct ratio was a nightmare simple solution swapped to 16" Alloy wheels (van rated )sorted and on checking speedo against gps was mush closer to the norm mpg improved significantly .
Fitted straight on .
hope this helps :)
C
Chockswahay
Thanks chaps....
@Techno100 Ah, do you mean the diameter of the circle is different on the 'stock' steel wheels? Therefore I assume a straight swop is not possible.....( I don't want alloys )
Techno
Jul 28, 2010
15,475
20,756
May 2010
Thanks chaps....
Makes no difference whether alloy or steel 118mm is 118mm and 130 is 130
Nov 28, 2010
157
124
Torrevieja, Spain
Laika Ecovip H720
December 2011
I have also 15inch wheels on my fiat based van and speedo is out by about 8km/h when travelling at 90km/h compared to the sat nav, and as above the wheel arches could accommodate larger tyres.
C
Chockswahay
Thanks @Techno100
Guess I will be sticking with the 15 inch wheels then.....
Apr 6, 2019
3,737
7,443
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
The heavier chassis Fiat's have 16" with PCD 130, as opposed to PCD 118 (distance from wheel stud to wheel stud is larger.
However, when I was looking for a steel spare wheel PCD130 16" I kept finding PCD118 16" wheels so I think they must be fairly common.
Reactions: DJT
6
63720
There was a fellow called White
Who could travel faster than light
He went out one day
In a relative way
And came back the previous night
I'm Sorry I Haven't A Clue.... ?
68c
Oct 22, 2019
1,814
2,791
Southampton
2001 Pilote 270
Since 2004
Not sure who you are thanking for a quick reply on a 4 year old thread.
My mistake, I was trying to a reply to an answer on Ebay, somehow got my screens mixed up on my tablet. I have asked Jim to delete it.
