Fiat traction? (1 Viewer)
Macytia
66
North Wales
Van Conversion
4 years
Is anyone elses new shape Fiat Ducato terrible on traction on everyting bar tarmac? Mine is terrible on grass, snow etc, and pressumably due to their being no weight over the front wheels:cry: I have just ordered 2 Vredstein winter tyres for the front, hopefully these will give me a bit more bite as all it wants to do is spin the front wheels:Doh:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
All the same, useless.
Winter tyres, if knobbly, will be less safe on wet tarmac. Let us know how you get on.
43,289
49,223
you wont get very good mileage from winter tyres.....
bread tray grip mats. :thumb:
Oh no!!!! i feel another bread tray thread coming on. :Doh::roflmto:
scotjimland
2,231
9,714
A Woosh bang
Please to not encourage these good funsters to break the law :Doh:
you'll have the BTP (bread tray police) on their case :ROFLMAO::ROFLMAO:
rainbow chasers
3,680
1,725
Mid Cornwall
Various
It is their weak point with them and all the other same types, new and old! Worse thing you can do on a country lane, is be nice and go on the verge - you'll never get off! lol!
If you have problems on sites, just reverse up inclines etc! They won't go up any other way!
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
no professional tyre fitter will install winter tyres on the front only put two on they go on the back I now expect to be told by lots of funsters I am wronghardhat
Losos
549
4
Suffolk & Czechland
Looking to buyi
N/a
Have a read of this, it would be quite funny if it wasn't so serious :RollEyes: :-
Link Removed
Macytia
Macytia
66
North Wales
Van Conversion
4 years
My need is not for full on winter/snow use, I just require a more aggressive tread pattern on the driving wheels. I was set to fit 4 but the local tyre garage said I would only need them on the drive wheels, they have 2 fitted to the rear of their sprinter, standard van tyres on the front. I have however seen the manufacturers sales videos on the net showing the benefit of 4 tyres in the snow and ice.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
its dangerous to fit winter tyres to the front only see here
Link Removed
  • A front-wheel drive vehicle with winter tyres fitted on the front only is out of balance at the rear, and the vehicle is more prone to spinning.
  • A rear-wheel drive vehicle with winter tyres fitted at the back only is out of balance at the front, and may go straight on at corners.
Peter James
259
If the Fiat Ducato, or any other front wheel drive van, is not getting enough traction that is because there is too much weight on the rear, and not enough on the driving wheels at the front. Weight distribution is the responsibility of the body manufacturer, not the van manufacturer. Wouldn't it be more appropriate to to say Bessacar/Swift or whatever is crap at traction, than Fiat?
Macytia
Macytia
66
North Wales
Van Conversion
4 years
My van is a LWB panel van conversion with a max running order of 3500kg, there is no way of getting any further weight over the front wheels on my van, and as it can run at 3500kg and is no way near that weight, the problem lies with poor design on Fiats part.
Peter James
259
But the converter designs (or ignores?) the weight distribution, not Fiat.
If it was being used as a panel van the weight would tend to be at the front, piled up at the headboard. It would only be evenly distributed in the unlikely event that the van was chock a block full. It is very unlikely a commercial van would be loaded heavier at the rear like many motorhome conversions permanently are.
43,289
49,223
yes, fiat could increase the front axle weight but that would defeat the point in a load carrying vehicle.
the gross weight cant be increased and still remain at 3500kg and any extra weight on the front axle must be deducted from the rear axle resulting in a lower payload allowance so no point having a front, driving axle at 2500kg to ensure grip and no load capacity at the rear.
all front wheel drive vans have the same problem....its not the converters fault.
if anything its fiats fault......too much torque and too low gearing in first.
my 4X4 hilux is even worse....RWD and no grip.....heavy 2.5ltr diesel lump, gearbox, heavy front axle and transfer box all sat up front.....only rear axle and next to no body weight at the back...wheel spin isnt difficult on wet tarmac.
any different and it wouldnt have a 1000kg payload.
try setting off in second on tickover...lower torque and higher gearing.
eric 83
87
46
leeds
30+yrs
i have actually been stuck more times in my renault master work van more times pro rata than my fiat motorhome, sometimes in places where no one else was there to assist!(no friendly motorhomers):thumb:
Peter James
259
Thats just wrong. You could have 2 axles each plated at 3400kg and a 3500kg overall weight. But it woudn't be economic to over engineer a commercial van like that. Also the lack of traction is nothing to do with the gearing. Its the percentage of the weight on the driving wheels. Thats the point of 4 wheel drive, to get more of the weight on the driven wheels, and less dead weight.
Macytia
Macytia
66
North Wales
Van Conversion
4 years
@ Peter,
Does that mean that there will be no benefit of fitting grippier tyres? I got stuck in a snowy carpark in the Lakes and got out eventually in 5th gear, I suppose having the van Remapped doesn't help either due to the increased torque at the front wheels.
43,289
49,223
so...if the converters make the rear body from single skin aluminium and put all the equipment and water tanks right at the front leaving just a bed at the back that would make it better ?
my kontiki has axle weights of 1850kg front and 2120kg rear.
that 1850kg includes the engine, gearbox, axle and running gear and bodywork including the overcab bulge.....then the two of us !
doesnt leave a lot to play with as far as moving stuff to the front goes. :Eeek:
43,289
49,223
yes peter, you could.
but a physical impossibilty in reality.....a 3400kg front axle will leave 100kg at the rear....that 100kg has got to include the chassis, axle and bodywork.
just the same as a 3400kg rear wil leave 100kg at the front.
you cannot exceed the gross no matter what the individual axle weights are.
so again...a physical impossibilty.
lack of traction has everything to do with gearing and torque.
the higher a gear the less torque is transmitted to the road...why do you think you change down to go up hill.....more torque in a lower gear for a given rev range.
JAY KAY
24
Shotgate, Essex
Right so that is the snow tyre idea out of the frame but my problem is that I have no grip at the red light grand prix, 3000 revs, 1st. gear, wet road, lights turn to green drop clutch, nothiing but white smoke from tyres. Now I do not have an overcab bulge but I do have an overbelt bulge plus I have cruise control sitting in the passenger seat who also has a similar bulge.
So what is this about bread trays and do you think they will help this traction problem. :RollEyes::RollEyes::RollEyes:
John D
43,289
49,223
yes bread trays will be purfic...but you need the special tarmac compatible ones...you sometimes find STONE baked flat bread comes on these:thumb:
but it sounds like you already have a bread BASKET....could you modify this to suit ? :ROFLMAO:
Feb 22, 2008
12,260
45,026
Norfolk
Nearly Tugging
Since 2004
Crumbs I never knew that :ROFLMAO:
JAY KAY
24
Shotgate, Essex
You've done it now Pappajohn, cruise control has just read the bread basket comment and has taken deep humbridge. :ROFLMAO::ROFLMAO::ROFLMAO:
bill2b
120
Lincoln
Hi Top
Ok our Laika on the Fiat is not too hot on Mud / wet grass, although we have always managed to get out! :roflmto: does some cracking sideways movements whan on full lock too :Cool:
Our old Transit got stuck on the wet grass outside our house, all perfectly level short grass but there it was chuntering away in reverse clutch released and me getting out to see if a drive shaft had gone :roflmto::roflmto:
Its part of the fun "I think" :RollEyes:
Phil
226
Herts
10 years
You could try reducing the tyre pressures at the front. If you get the front and rear axles weighed with the van fully loaded, as if you were going on holiday, and then ask the tyre manufacturer to recommend suitable tyre pressures you will probably find that the recommended pressure for the front tyres is 50 psi or less. The lower pressure makes a considerable improvement to the grip. IMHO.
Phil.
Oct 29, 2008
5,056
5,909
West Yorkshire
PVC
since 2008
We changed from a 2.0tdci FWD Transit which wouldn't move on wet grass to a Ducato 2.8JTD Tag axle van. We were suprised on how good the Ducato was on grass and in mud compared to the transit, dont know if it was because of the tag axle setup though.
Jan 18, 2010
538
138
Airdrie Scotland
6 years and 20 years as a tugger
Traction
I'm fortunate i have the bed above the front wheels simple ask wife to have a long stay in bed IE lots of weight over front wheels simple lots of traction
Bill:ROFLMAO::ROFLMAO::ROFLMAO:
slverdreamers
185
42
Worcestershire
18yrs
Fiat traction
We have the old type '56 A class esprit with the same problem, to the extend we are still considering swopping for rear wheel drive. Had ducatos on a Hobby and small dethleffs in past with no problem, have brought some long grip mats for all the wheels which gives us a run off, expensive, but they work, we thought we were the only one with this problem
Peter & Glynis
