Fiat light cluster (1 Viewer)
May 31, 2015
11,679
44,507
Cornwall
Ducato PVC
Getting Better
there are plenty of them on flea bay going cheap, is it as simple as changing them ?
Will the mileage be the same? Probably change it for another fiat crap one..!
Has anybody heard of or used cartronix for a repair..?
Or who have you used.
I need to get mine done... I can't wait for fiat to organise anything..
Appreciate any help..(y)
Silver-Fox
9,265
29,071
Cheltenham Spa
Rapido
im a not so newbie
Does your faulty one affect the use of the vehicle?
If not use as is or change one yourself and still get fiat to order one foc and tell them you will fit it.
You can then sell on or swap for the new Fiat one and sell the other one you bought.
Can't help with the repair side or mileage but my guess is mileage is held on the clocks.
Jul 10, 2016
414
385
hucknall
Swift bolero 712sb
10 years
How old is the van? If it's newish an low miles contact fiat direct. Even out of Warren. Got mine done free
Lenny HB
53,417
149,919
On the coast in West Sussex
Hymer B678 DL
Yep used Cartroix to repair the cluster on my last van, dropped the cluster into them picked it up a couple of hours later, no problems with it after the repair.
If you have repaired just plug it back in and it works, if you fit a replacement unit you will need to visit a Fiat dealer afterwardsI think they have to set the ECU to recognise it.
Very easy to remove, 2 screws on the front corners of the hood and pull frowad and up from the back (windscreen side) it is clipped there. Then just 2 screws & the electrical plug to remove.
Just smiffy
May 31, 2015
11,679
44,507
Cornwall
Ducato PVC
Getting Better
That's good enough for me, thanks Lenny I'll send it off to them, £150 on fleabay.... I can't wait for fiat, there useless ...
Mr B
990
1,889
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
We swapped our instrument cluster and the mileage display is separate, so I just put ours into the fresh one( it had done 100k and ours only had 25k on)
Took about 30 mins to do
