FIAT horn problem. (1 Viewer)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
The pre-X250 is notorious for the horn failing. Almost certainly due to lack of use.
I've seen comments "You take the bumper off" "Pull the wires off and fit one elsewhere".
It's dead easy on my 2003 one.
1. Remove grill - 4 screws.
2. Remove NS headlamp - 2 screws and pull.
There is the horn before you.
Fix horn.....
Remove tone adjuster screw on top. Squirt contact cleaner down hole. Replace adjuster screw whilst someone holds horn push - sorted. Squirt something on the spade terminals while you are at it.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
And do it all again next week:thumb:
Stick a new one on you tight bu**er,
Bet you dont post you had to do it again and you will:RollEyes:
ourcampersbeentrashed
7,574
4,348
East London
well over 5 years
Just make sure you use the new one more often ::bigsmile:::bigsmile:::bigsmile:
Theres nothing better to release frustatration than banging your horn
