Fiat headlights
Discussion in 'Tech/Mech General' started by Portland, Feb 5, 2015.
  1. Portland
    Portland Funster
    Oct 31, 2013
    368
    537
    Cheshire
    Hi, I'm thinking of importing a 2013 Fiat based motor Hymer tramp. and need to modify the headlights to conform to the UK. Has anyone done this and if so how do I do them
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,221
    15,204
    Leeds the one up North
  3. Sheddy
    Sheddy Funster
    Oct 20, 2010
    953
    4,805
    Burry Port South Wales / Benidorm
  4. Techno
    Jul 28, 2010
    14,221
    15,204
    Yes mine was imported 2008 so escaped the above. I have beam benders permanently fitted and no noticeable impact on vision.
    I don't know about 2013 headlights but up to 2011 are cheap as chips
  5. Techno
    Jul 28, 2010
    14,221
    15,204
    • Like it Like it x 1
  6. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,928
    6,827
    West Sussex
    Yes you will have to change them takes about 10 min a side. There is is a plastic cover above and below the headlamp that need removing before you can access all the mounting screws. The plastic covers are held by a couple of screws on the inner edge, the outer side just clips in. It really is easy. You will also need to change the speedo dial that also only takes 10 min replacement dials from Lockwood Dials, make sure you get the right one 3 versions for the x250. Rear lights are OK has Hymer always have twin rear fog lamps.
    Just for info the X290 is even easier just 2 screws on the lamp no plastic covers.
    Edit:
    If you buy lamps of eBay be aware the later ones have a different connector they changed the wiring loom, I think there is an adaptor available not too sure.
  7. Techno
    Jul 28, 2010
    14,221
    15,204
    Why is it so time orientated Lenny? It takes as long as you want, take it easy have a cuppa (y)
  8. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,928
    6,827
    West Sussex
    Just pointing out it's a quick and easy job so as not to scare someone off from tackling it themselves & shelling out loads of cash getting someone in to do it.
  9. Techno
    Jul 28, 2010
    14,221
    15,204
    Well I think you need more than 10 minutes personally but yes it is easy once you have done it once.
    You also need to be sure when replacing the front headlight bolt that the beam adustment screw does not move! as it is a left hand thread so screwing in the fixing bolt can wind it out.
    here shown OUT
    [​IMG]
  10. Portland
    Portland Funster
    Oct 31, 2013
    368
    537
    Cheshire
    Thanks for the info up till now. I'm told the lights are adjustable to dip in the right direction. but the replacements don't seem to dear. Biggest problem now is trying to find how I can pay the vat the gov/UK site is a nightmare
  11. Techno
    Jul 28, 2010
    14,221
    15,204
    There are indeed adjustment points on the unit but I think it is a closely guarded secret or specialist job. Hence being sold as one or the other.
  12. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,928
    6,827
    West Sussex
    I think you are confusing the lights with the Hella projector lamps fitted to A Class vans these are adjustable to straight dipping.
    What VAT, no vat payable on vehicles over 6 months old or done 6000 km.
  13. Techno
    Jul 28, 2010
    14,221
    15,204
    There are also hex key adjusters on X250 headlights BUT BEST NOT play with them without the knowledge.
