Fiat Engine Management. (1 Viewer)
scotjimland
2,324
10,060
A Woosh bang
On my Fiat Seicento disconnecting the battery, (leave disconnected for a few mins then reconnect) would reset it ..
Wow
Trader - Engine ReMapping
Sep 8, 2010
68
7
Charlestown, Cornwall
Depends what and why you are trying to reset?
An engine management light? You can clear some codes by leaving the battery disconnected, as mentioned but obviously they come up for a reason.
You can also do a further reset by disconnecting the battery DONT DO THIS WITHOUT! and join the two leads together for 10 seconds, this clears any capacitance in the electronics.
If those dont work you need a friend with an OBD scanner or a wad of cash at a dealer to clear any codes.
Is there a simple way, or should I say easy way of resetting the engine management system.
Don
niggle
Banned - Rule 1
Banned
Aug 5, 2010
804
601
SOUTH AND FRANCE
A CLASS
:thumb: i got the address of a company in slough that sells the program on c/d and allso the leads you need for the laptop,, they will show you how to run it with you allso while you are with them,,you allso get a full renault /fiat code book,, p/m if need add :ROFLMAO:
Gonewiththewind
Gonewiththewind
846
36
Lancashire
July 2007
Thanks Wow but, Without What !!!!!!!!!!!!:whatthe: And the wad of money is reason for asking, I aint got it.:cry:
Thanks Niggle but I am in Lancashire and Slough is a loooooong way to push it.:ROFLMAO:
Thanks Jim will give that a try later
Thanks to all responses. Most great full.
Don
freelanderuk
1,018
534
Saltfleet/Lincolnshire
c class
you can down load the fiat software to read and reset the codes from the fiat forum and buy the leads of ebay for a few pounds , i have the software and leads for mine , very easy to use
have a look here Link Removed
