Fiat Ducato X250 3.0 Wiper Relay
Discussion in 'Tech/Mech General' started by dpsuk999, Jun 17, 2015.
  1. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    317
    292
    Leeds
    On our travels through Croatia and I seem to have a problem with my wipers. The intermittent does not work, I can't hear the relay clicking on and off, it just continues to wipe and then when I turn them off they seem to 'park' half way up the windscreen or at different places and not at the bottom.
    I think it's the relay which may have gone as I've cleaned the contacts on the wiper motor connector.
    Does anyone happen to know where the relay is located for the wipers? It's either the fuse box at the drivers side or in the engine compartment but I can't identify which is the relay for the wipers.
    Cheers, David.
  2. Mel
    Mel Funster
    Oct 6, 2012
    2,094
    2,122
    De Haan Belgium
    I cant help with where it is.
    But if you can hear it can't you feel the relays till you find the one that clicks.
    But I'm sure someone will know which it is before too long.
    Mel
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    A good chance that it's a motor unit fault
  4. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    317
    292
    Leeds
    I can't hear any relay clicking when on intermittent which made me think it could be the relay. When I choose intermittent it just wipes at the normal speed and all the other wiper functions work (fast speed etc) ok, apart from parking at different angles.
  5. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    317
    292
    Leeds
    Anyway of testing it? The motor functions perfectly ok apart from intermittent which is controlled by a relay so I wouldn't have thought it was the motor but any tests I can do?
  6. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,801
    1,025
    Cark, Cumbria
    I know someone who had the same fault on a Peugeot
    They were told "there is no relay, the wipers are controls by the BSI(computer) & it would cost £1000 for a new one"
  7. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    982
    1,751
    Essex
    Sounds more likely to be a microswitch that tells the motor when to stop when at the natural park position. I'd guess it's either somewhere in the motor or wiper assembly
  8. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    982
    1,751
    Essex
    I sincerely hope he took it to a real mechanic for a second opinion :mad:
  9. DP_JAY
    Mar 17, 2010
    1,801
    1,025
    Cark, Cumbria
    Yes & it was confirmed so it was sold
    Try googling BSI wiper fault?
  10. Techno
    Jul 28, 2010
    14,107
    14,921
    Mine is working fine and no relay noises
  11. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    317
    292
    Leeds
    Hi Andy, thanks for confirming no relay noise when working on intermittent so I'll continue searching, I've read maybe disconnecting the battery for 5 mins may reset it
  12. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    317
    292
    Leeds
    Just been having a look and looks like I can remove the motor quite easy, although even when I push the stalk down 1 for intermittent the wiper works as if I've chosen normal speed and if I turn the stalk to increase the intermittent gap it does nothing so could point to an electrical problem
  13. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    317
    292
    Leeds
    Well I finally got around to removing the wiper assembly to inspect the motor. It was quite simple to remove, first remove the wipers from their spline then undo the outer nut holding the wiper assembly to the body just below the windscreen. Then remove 2 bolts which held the whole wiper assembly, unplug the connector and after a bit of jiggling I got the assembly out:
    • Like Like x 1
  14. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    317
    292
    Leeds
    I then removed the 6 screws which held the front plate of the motor on and removed the plate. It was obvious from what I saw that what was causing the intermittent not to work and the wipers parking at different places was the middle connector had somehow detached from the solder connector:
    After cleaning them up:
    So I removed the contact from the block, filed it to remove any old solder:
    And re soldered it:
    All put back together again and working perfectly now.
    Hope this helps any fellow funster who finds their wipers don't work as they should. Apparently it's a common problem with them.
    Dave.
    • Like Like x 9
  15. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,964
    2,793
    Kendal, Cumbria
    The giveaway is not parking + no intermittent. Both rely on the parking switch in the motor as you found.
    • Like Like x 1
  16. Techno
    Jul 28, 2010
    14,107
    14,921
    Thanks for that David (y)
  17. ivan pitten
    ivan pitten Read Only Funster
    Jul 8, 2015
    bridgend midglamorgan
    can anyone help me my main batterry goes flat even when hooked up to the mains battery 2 is ok it is a new 125 amp battery and how can i test the charger in the van to see if that charger is working right the altenater is good when running they all kick out 13 amps plus so its not that
  18. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    769
    634
    Dumfries
    I can't help butI would suggest you start a new thread about your problem then more people will see it. Some clever guys will be along to help you (y)
  19. Valkman
    Valkman Read Only Funster
    Apr 11, 2013
    37
    33
    United Kingdom
    Thanks DAVE. That's brilliant! Will have a look as soon as I can.
