Fiat Ducato problem cold start.
Discussion in 'Fiat' started by joner8888, Feb 27, 2012.
  1. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
    1997 Fiat Ducato 2.5 TDI, 35k miles.
    When starting from cold ,it starts first go but smokes like a train for a about 60 seconds.
    There seems to be no glow/pre start light and is fine on hot starts and when running.
    It is almost as if there is a incorrectly adjusted automatic choke, because when revving up, it sounds choked and pumps out blue/black smoke.
    I can live with is but---when leaving a calm, quiet, campsite on a clear morning, it is as if i am leaving behind me a trail from the flying scotsman and leave all chocking on their bacon butties!! :Eeek:
    Is there a choke on it than can be fixed?
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,287
    16,960
    Liverpool.
    Sounds to me like one of 3 things. Firstly it could be an injector dripping overnight leaving unburnt fuel on top of the piston. If the smoke smells of diesel,that's your problem. Secondly a blocked fuel filter will cause the same symptoms. Thirdly get your heater plugs checked.
  3. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,106
    13,477
    Ramsey, Isle of Man.
    Or it could be the valve seals.
    Craig
  4. joner8888
    Jan 4, 2012
    2,190
    1,971
    somerset
    OK, Thanks for that.
    I have just tried it this morning---no problem--no smoke :thumb:!
    It seems to be a intermittent problem-- and yes it does smell of half burnt diesel (black) and sounds like it`s choked .
    As if on a old manuall choked petrol car , the choke was left pulled out.
    It clears after a short while bur stinks out a campsite!
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,770
    6,291
    South yorks
    Sounds like the turbo is on the way out.Take off air intake to turbo and put your finger on the turbo fan pin,try wobbling it.If it wobbles that's your problem :thumb: Do not worry too much they go for yrs like that,once it clears it's throat it is normal until cold again
    terry
  6. joner8888
    Jan 4, 2012
    2,190
    1,971
    somerset
    I will try a redex diesel fuel system cleaner first,run that through and see what happens,it may unstick the injector!:thumb:
  7. Snowbird
    Apr 24, 2009
    10,287
    16,960
    Liverpool.
    I had the same problem here with my Peugeot 2.5 turbo diesel and had the injectors reconditioned. This cured it till I was up in the mountains and it started doing it again. I checked the fuel filter and found it half full of water and crap. Changed that and its been fine since.
  8. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    So if this has no glowplug lights how does it cold start?
    does it have glowplugs?
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,770
    6,291
    South yorks
    Not sure on this model but some common rail engines have no glow plug lights and direct injection (trannys) do not have glow plugs
    terry
  10. jhorsf
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    On some 2.5 fiats the diesel is preheated if this is not working it would give these symptoms its usually a BERU GF 974 ? plug in the inlet manifold
    its called a flame start system It would seem the flame glow plug fitted in the inlet manifold firstly heats up to temperature. Then some seconds later when the plug is hot and you start the engine the solenoid next to it is activated to divert some diesel into the plug. This ignites creating the flame.
    not certain yours will have this but I would like a pound on it:Rofl1:
  11. jhorsf
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
  12. jaygee
    jaygee Funster
    Mar 21, 2009
    1,181
    739
    Harwich, Essex
    if this is the fiat engine then as far as im aware these do not have heater plugs but rely on a small fuel injector which is fitted into inlet manifold.these engines can tend to smoke after start up and on idle.
    Make sure Starter motor is top notch as this can effect supply to start injector
    HTH
    Tony
  13. jhorsf
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    It is not a small injector please read my post above
    Some companies that make them call them thermostarters
  14. joner8888
    Jan 4, 2012
    2,190
    1,971
    somerset
    I suppose it must have some glowplugs--there is no light at all for it.
    I know that there is a symbol as a curly wire that should light up - but i can`t see any!
  15. Hycon
    Hycon Read Only Funster
    Oct 6, 2008
    91
    16
    N.E Lincolnshire
    I have a 2.5 Ducato Hymer with the Thermostart system as jhorsf discribes in his post.Same staring characteristics .Heater only comes on at minus temperatures and flashes for a while even when engine has started.
    Sid
    • Like it Like it x 1
  16. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    As you probably know deisels require atomised fuel and high compression to fire... when its cold the fuel does not atomise well enough to aid clean start ups, so some form of heater / method of aiding improved atomisation is usaully incorporated. to further complicate things these days you have computerised engine management systems.
    i would be looking at injector pressures and whatever aid to cold starting is fitted ( deisels do not technically have a choke.:Smile:
  17. joner8888
    Jan 4, 2012
    2,190
    1,971
    somerset
    Problem solved--
    Read a few links from you guys on here.
    It seems that i am used to modern diesels where i start, rev, and go,
    This type has a flame plug on the manifold and i would have started it and revved it full boot trying to clear it, it just made it worse.:Blush:
    I added some injector cleaner to the fuel and ran a few miles yesterday.
    Cold start this morning-- i left it on idle for 30 seconds or so and pulled away.
    NO smoke or choking sound! :thumb:
    I think revving it was too much of a surge for a small flame plug to keep up and blew out unburned diesel.
    Thanks for advice :thumb:
    oh,also--turned off fridge/wipers/heater motor so starter got all the power.
    • Like it Like it x 3
  18. Terry
    Terry Funster
    Dec 27, 2007
    10,770
    6,291
    South yorks
    Hi joner8888,check the turbo as these are the symptoms that presented when my turbo was going years ago hence my first post.
    terry
  19. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,106
    13,477
    You should never give a cold engine a boot full of throttle! An engine is like me, it likes to wake up first, warm up, then get ready for work.
    Never, ever, thrash an engine from cold. Let the oil find it's way around and let it warm up first.
    Craig
  20. Snowbird
    Apr 24, 2009
    10,287
    16,960
    Liverpool.
    How many people I see doing exactly that:Doh: Also flog the horse to death all day and stop and switch off immediately instead of letting it cool down for a few minutes.
