Fiat Ducato gearbox problems
Discussion in 'Motorhome Chat' started by keith c parker, Mar 19, 2015.
  1. keith c parker
    keith c parker Read Only Funster
    Mar 19, 2015
    3
    Durham
    Hi, I have a Fiat Ducato 1.9 turbo diesel T reg, 1999. I have a problem with the gearbox going from first to second, it grinds but goes in. From third to fifth and reverse there is no problem. We have asked the fiat dealer and other gearbox repair companies. they all say the same. This year of motorhome they can not get the parts to repair the problem.
    Does anyone have any idea where I could get this gearbox repaired or get a re conditioned one. I have been told it is an ML gearbox if that is any help.
    Thank you very much.
  2. trekkin
    trekkin Read Only Funster
    Sep 12, 2014
    333
    495
    Staffordshire
    Welcome to the forum
    Sorry cannot help but I'm sure there will be someone along soon with an answer, there is a wealth of knowledge on here and rarely does a question go unanswered.
    • Like it Like it x 1
  3. PeteH
    PeteH Funster
    Nov 22, 2007
    2,264
    2,791
    East Yorkshire
  4. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,521
    Lancaster
    Try this. Type EPER into your Google Search. That will open Fiats full parts inventory. Choose your model, then you may be asked to enter your vin number. Go to gearbox. All your part numbers are there. As far as I'm aware at this time, Fiat still supply everything for your gearbox. (y)
  5. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
    Hi & welcome
    Is your problem heat related ? my 2.5 hates shifting when cold & prefers to be warmed up & if I do have to move it straight off from cold I find it ridiculously hard to change gear until its warm.
    I also wondering if any previous owners have found this & forced gear changes on your box.
  6. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,521
    Lancaster
    This company supply reconditioned gearboxes.
    http://www.stockportgearboxcentre.com/ They have a good reputation, and will advise over the phone. (y)
    However, it could be that you have a worn linkage problem.
  7. mariner
    mariner Funster Life Member
    Nov 21, 2013
    1,284
    3,798
    Isle of Dogs, but mostly Artola Spain.
    Had a 2004 Ducato 2.8JTDI with that problem.
    2nd gear syncro was shot, but being an ex army driver trained with crash gearboxes, I just used the double de clutch method to change up and down using 2nd gear.
    Much cheaper than a new box.
    :cooler:
    • Like it Like it x 3
  8. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    3,199
    8,311
    Market Harborough
    Sorry can't help you with your problem but welcome to FUN. (y)
  9. pops
    pops Funster
    May 1, 2012
    430
    384
    south glos
    I agree with Mariner, If you know how to double declutch do that. I found with my 1999 autosleeper Ravenna if I changed up slower it would fall into gear ok.
  10. Barclaybasher
    Barclaybasher Funster
    Apr 13, 2012
    2,462
    7,366
    Derby
    With my 1991 Renault Trafic diesel I 'blip' the throttle between gears, it just makes changes easier.
    My previous MH, a 2004 Ducato had a seized linkage - a common problem that makes you think that the gearbox is a problem - sorted by freeing off the linkage
  11. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,334
    1,688
    Dover
    M 6 speed transit was very difficult to get into 4 gear, But when i let the stick find it's middle sprung position it just drop in. I was catching the gate either side of the gear slot when i hold it loosely it slides right in.
  12. keith c parker
    Mar 19, 2015
    3
    Durham
    Thanks very much for all your advice. I have tried doubling my clutch up and down the box and slowing down to see if it drops in. I've been told by a gearbox company that it's the baulk ring that is worn and stopping gear changes and
    For my model they no longer make parts for the gearbox.
    I would like to think someone could tell me different.
    Thanks again for the help.
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    Seized linkage will not cause gear crunching...it will just make shifting harder.
    Gears grind, linkages don't.
    Sounds like second gear synchro is shot.
  14. pappajohn
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    The baulk ring is part of the syncro hub and gets everything lined up and turning at the same speed before fully engaging the gear.
    If the ring is worn the gears rotate at different speeds causing the grinding as the gear teeth jump over each other.
  15. keith c parker
    Mar 19, 2015
    3
    Durham
    Thanks for that. It's always better when someone takes the time to explain.
    Much appreciated.
  16. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,521
    Lancaster
    Already did. Read post's #4 & #6.
