Fiat Ducato Dash Swapped and now has a new fault! (2 Viewers)
Nov 3, 2016
881
1,679
Derbyshire, UK
Bailey Autograph
Since 2016
What the hell is is with these Ducatos and there bloody dash binicles
Took it in today for a replacement unit due bleed on the warning lights. About 5 of them were dimly lit up.
All good to go after the swap I am told. Get in and set off and the total miles was flashing. I figured it maybe needs a mile or so to click in after been set on the new dash so I set off to my Motorhome dealer to have another issue fixed with my Truma heater. And nope it flashed all the way.
Asked the guys here to look at it to see if it just needed the enter button pressing if there is one lol
Nope told it's buggered and needs a new unit. Errrmm newer than an hour old?
Good lord I dispare. Off to France on Wednesday so it will just have to flash for the next 2 weeks. Dam Italians and there funny electricity.
ambulancekidd
Sep 23, 2014
10,366
28,389
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
Its a FIAT Fix It Again Tony, oh & we're no better off, we have a Peugeot Boxer & coming to that from a Sprinter is like heading back into the dark ages. A total shock to the system.
Hope you get it all resolved soon.
Feb 24, 2013
13,083
101,447
Bolsover, Derbyshire
Hymer S800
not long enough
With a bit of luck it will not be adding on the extra miles at least
Pain in the butt though, you have my empathy o_O(y)
Riverbankannie
10,532
61,533
Bristol
IH 630 RL PVC
Couldn't decide which button to select for your post!
Hope you get it sorted.
Gellyneck
9,234
18,208
Scotland
More than toes wet now!
Now this is only from memory, so most likely wrong then, but I think our replacement binnacle mileage was flashing until the technician plugged in something or other and reset this to the previous speedo mileage.
Have you spoken to the FIAT place?
Derbyshire wanderer
1,288
2,390
Derbyshire
C class
15 years
I think they did not do a updated reset when fitting the new binnacle.
When mine was done it was exactly like that but I noticed before driving away.
It's something to do with it knowing the mileage on the display does not match all the other ecu's as in 'I think I may have been clocked' so puts the flashing mileage as a warning.
It will take the Fiat computer about 30 seconds to put it right if you take it back to them.
davidathomas42
Nov 3, 2016
881
1,679
Derbyshire, UK
Bailey Autograph
Since 2016
Spoke to the dealers. They say a 2min fix and I can pop in tomorrow to be done while I wait.
Also notice the suggested change up a gear indicator is not there now. But that's no bad thing. Might ask if that can be left off
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
Dont wanna sound negative but "dont hold ya breath" they are a bloody awful design, problem after problem after problem
TheBig1
17,630
43,270
when a 3rd party company can repair the faulty binacle and offer a lifetime warranty on their repair, why cant fiat or peugeot?
43,329
49,441
Probably because the number going wrong is far outweighed by those not going wrong and means it simply aint worth them worrying......just like the judder issue.
When sufficient numbers are reported (possibly thousands) things may change....just like the judder.
Deneb
1,598
2,334
Europe
PVC
It need a proxy alignment to register it with the body computer. 2 minute job with diagnostic software. I suspect someone forgot to do it when it was changed! Repaired clusters don't need doing because they're already registered to the vehicle, but a new unit has to be introduced into the system.
davidathomas42
Nov 3, 2016
881
1,679
Derbyshire, UK
Bailey Autograph
Since 2016
It got done. As as said took 2min to do. Suggested gear change is also back :-(
All I need to do now is drive in the dark to see if any are faulty again or wait until they are again. Not holding out much hope for it long term but as long as it's just false indications that's ok.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
The problem is, the dealer just swaps the faulty one for another potentially faulty one, the repair company finds the faults and fixes them.
We were lucky when the dealer swapped ours, no more faults showed up in the few months before we sold the van.
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
5 years, feel free to ask me about the Carado!!
Just had my console fixed for the light bleed under warranty. Mechanic said he had done 'hundreds'. I lived with it for over a year but obviously its an MOT failure so it had to be done!! So far so good (y) apart from reseting the finnicky menu system which I managed to change into Italian :doh:
Gellyneck
9,234
18,208
Scotland
FIAT Commercial behind Shieldhall recycling plant by any chance?
If so, did mine a couple of times!
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
Yes, bit of eye opener compared to your regular car dealer ;)
I asked them to do an oil and filter change a while ago cost £180 :Eeek::Eeek:
I watched The mechanic in the bay take 20 mins to unscrew the oil filter (to make up the time). So I only go there for warranty repairs. :(
xulih
100
800
58.89º North
Autocruise Accent
Newbie
What is it with main stealers, why was it not done properly to start with ! I had the same when I put my Hilux into Toyota to get steering rack replaced under warranty, went to collect it and airbag light was on, went to see service manager who says " oh they have just forgot to reset it,2 minute job" wait while they reset it and red faced service manager comes back to explain that mechanic had not removed connection to clock spring in steering wheel airbag before removing the rack and had broken it !
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
I had a recall for my Disco 3 for the high pressure, fuel pump. They returned the car with diesel pissing out of it !!! Another time they put the EGR system back without all the bolts on, I had to return it twice to get it properly done.
Needless to say Town & County LR in Aberdeen is long gone, worst dealership ever !!!
xulih
100
800
58.89º North
Autocruise Accent
Newbie
Shocking ! mind you they probably thought it was normal to have fluid pissing out of a Land rover :D
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
You may scoff, but I just had a lift in a D4 HSE, a magical floaty carpet ride across the third world donkey tracks of East Ayrshire, where my FIAT van base a few minutes previously was causing my fillings to rattle loose ! :Eeek:
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
I think the suggested gear change is stuck in Italian driving mode :(
