Fiat Ducato 5th Gear
Discussion in 'Tech/Mech General' started by SwankyCandles, Dec 29, 2014.
  1. SwankyCandles
    SwankyCandles Read Only Funster
    Jul 12, 2014
    10
    4
    Our 5th gear is slipping out of gear. We have been told it's a worn cog and needs to go into a transmissions place to be looked at. Does anyone have any advice on this please? Anywhere around Stalybridge that won't 'rip us off'. It's been under the care of a place in Glossop this past year and they made the recommendation!
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,615
    22,781
    Narrfoook
    It may well not be the 5th gear or indeed the selector but could just as easily be the linkages worn
    A pain in the bum job but about a 1/5th of the price of a gearbox jobby
  3. Carol
    Carol Funster Life Member
    Oct 2, 2007
    10,599
    15,374
    North Wales.
    Know it's not directly the answer you asked but in the meantime don't forget not to put it into 5th gear for the first couple of miles as the 5th is a add on (or something like that) and the gear box oil does not get to it for the first couple of miles giving quite a few people problems with it. Quite a bit in the search thingy on Fun about it.
    • Like Like x 3
  4. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,068
    2,938
    Essex
    I had a new 5th gear put in, but instead of 40mph at 2000 revs, does 60 at 2000 revs.is a proper Renault part.
    • Like Like x 2
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,952
    17,632
    YO11 2BD
    But not the correct part.
    There are different ratios for different (same) vehicle uses.
    • Like Like x 1
  6. pappajohn
    Aug 26, 2007
    29,952
    17,632
    YO11 2BD
    Any garage worth its salt can do the job....it doesn't require whole gearbox removal or dismantling
    • Like Like x 3
  7. stcyr
    stcyr Funster
    Apr 11, 2011
    1,680
    1,114
    Normandie
    It's a 'through the wheel-arch' job.
    Separate housing, bolted to gearbox.
    • Like Like x 1
  8. wizza
    wizza Funster
    Aug 3, 2008
    114
    54
    Essex
    Done a few over the years,It can be done through the wheel arch, if its jumping out of gear prob worn fork people rest their hand on gear lever when in 5th and it wears the brass on the fork. Will need stripping to check.
  9. SwankyCandles
    Jul 12, 2014
    10
    4
    Thanks for your replies folks, we really appreciate your valuable help! x
  10. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    • Like Like x 1
  11. The Wino
    The Wino Funster
    Mar 23, 2012
    1,194
    2,203
    leicester
    40mph at 2000 revs sounds way too low gearing to me our transit in top (6th) pulls 75 mph at 2000 revs!!!
  12. Jaws
    Sep 26, 2008
    18,615
    22,781
    Narrfoook
    Unless it is a petrol engine ?
  13. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,091
    2,933
    Kendal, Cumbria
    The damage to the engagement dogs visible in the photo is definitely not due to a lack of lubricant, the first signs of which would be damage to/excessive wear of/overheating of the teeth of the gears. The dogs do nothing once the gear is engaged so damage only occurs during a gear change. For this to happen the syncro cup, cone, or baulk ring, has failed or is badly worn.
    • Like Like x 1
  14. Laikavirgin
    Laikavirgin Read Only Funster
    Jun 28, 2008
    58
    40
    Leeds
    Not sure how you diagnose with no vehicle info other than Ducato, but our 01 Ducato 2.8jtd had the dreaded 5th gear problem, but on the first day of a three week trip, so we just carried on, 4th is more than up to the job, 5th is mainly an overdrive gear.
    We got it fixed at a place in Wakey for £160ish, sold it soon after.
    We also lost 5th & reverse in the 07 Relay, but that was due to 2 bolts working lose and falling out from the dash levers mounting, easy fix.
  15. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,143
    9,819
    Lorca,Murcia,Spain
    Is the 5th gear fault only on the 2.5+ engined models ?
  16. Laikavirgin
    Jun 28, 2008
    58
    40
    Leeds
    As far as I knew it was only >06 models, 06> is a different gearbox altogether.
  17. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,143
    9,819
    Lorca,Murcia,Spain
    Mines a 1.9 Normally aspirated Fiat diesel 1989.
    It doesn't have the black steel end plate as is all aluminium & cannot be removed without supporting engine as the end of gear box is sandwiched by the engine/gearbox mount bracket.
    I'll have to have a good look.
