Fiat Ducato 2.8idTD 1999 screeching noise
Discussion in 'Tech/Mech General' started by EA7VPG, Dec 4, 2013.
  1. EA7VPG
    EA7VPG
    Jul 27, 2011
    47
    28
    Malaga, Spain
    Hi..... sat here in Peniscola thawing out after a two month trip round France and Italy.
    After start up when the engine is cold I get a screeching noise from the engine which sometimes disappears straight away or disappears when I change gear. Generally it is not for long but can be rather disturbing for the neighbours when departing from the campsites. On one occassion entering the toll whilst the engine was hot it did the same, screeched then stopped after changing gears which I assume has something to do with the rpm of the engine. I have had the alternator belt tightened. Could it be the water pump, I seem to remember vaugely one of my old Volvo's had the same problem. If it is the water pump is there any such product as an additive you put in the cooling water to lubricate the seals ? juts a thought.
    The engine has 187,000 Km on the clock.
    atb:Smile:
  2. Daedalus
    Daedalus Funster
    Nov 3, 2013
    77
    143
    North Cumbria
    How old is the alternator drive belt?
    If it's a fair age - or even if it's been run in a slack condition for a while - it could be polished, which will cause slip - particularly when cold, or revving to pull away (when hot).
    Might be worthwhile having it changed, or at least checked by a decent mechanic :thumb:.
    Daedalus
    • Like it Like it x 1
  3. icantremember
    icantremember Funster
    Sep 2, 2010
    5,395
    7,497
    Nr Watton in Norfolk
    I agree with Daedalus ..... you have a belt slipping which probably needs changing.
  4. laneside
    laneside Funster
    Aug 14, 2009
    3,577
    5,602
    Oradour sur Vayres
    Could even be the thrust race on the clutch-----feather it and see if you can duplicate it
    • Like it Like it x 2
  5. dogman
    dogman Read Only Funster
    Oct 24, 2013
    551
    444
    chepstow
    Did tightening the belt make any difference at all?
    Does it happen as you are letting out the clutch or will it do it before selecting a gear?
