Fiat Ducato 2.8 jtd Cig lighter fuse (1 Viewer)
Aug 20, 2007
574
637
Leyland
Frankia I7300 BD
since 1997 (many years tugger before then)
I bought a ceramic heater from Maplins to supplement the lack of heating coming from the fiat system. 30 mins later maplins heater not working. Tried heater in my car and it works ok. So, looking through fiat owners manual it tells me cig lighter fuse F44 which is located under panel on left hand side of dash.
F44 (15 amp) fuse is ok. When I remove this fuse the power socket (do not exceed 180 watts sign on it), which is fairly close to the cig socket, goes dead. So presumably the manual must be wrong.
Does anyone know where the cig lighter fuse is ?
I daren't use the power socket for the ceramic heater as if I blow this one then nowhere to plug the sat nav.
The cicular bezels of both sockets light up when side lights are on.
regards
Allen
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
From memory the cig fuse is in the right hand fuse assembly next to the steering wheel. I will find my fiat CD manual and check.
Andy
Jan 27, 2009
872
3,359
Leyland Lancs
since 2001
I would try F52 (Front outlet). On the assumption that they may have got F44 and F52 reversed ?
Sep 23, 2007
1,710
1,970
Leicestershire
Thought it was F53???
Andy
43,319
49,401
do you have a multimeter with probes ?
if so then connect black to an earth point, then touch the red probe to each fuse in turn.....look closely and you'll see there is a very small bit of the 'metal' fuse blade showing in each end, on top, of the plastic fuse.....touch each end in turn.
the fuse with power at one end but not the other is the blown one.
if the socket needs ignition on then turn it on to check.
a lot easier than pulling fuses and loosing the radio code.
BTW....a standard fag lighter socket will have a 10a fuse.
872
3,359
Leyland Lancs
since 2001
My (2004) Fiat Handbook gives F53 for Direction lights, Hazard lights and Instrument panel ?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I would check every one, Having had trouble locating a fuse for the hot water system, it was found, clearly labled Interioir lights:Doh:
Take nothing for granted
Geo
walburga
Aug 20, 2007
574
637
Leyland
Frankia I7300 BD
The prize goes to sam (from Leyland , so he must live near me).
This is what it's like in my fiat ducato 2.8 JTD 2004 reg.
In the manual F52 is front outlet (180 watt power socket adjacent radio), and it should be a 20 amp fuse,..... but F52 is the fuse for the cig lighter, and was a 10 amp fuse. Hence the 120 watt (15 amp) maplins heater blowing it !
The 180 watt front outlet power socket is on F44 which is a 15 amp fuse.
It's gets slightly more confusing :-
In the manual it says the cig lighter should be protected by a 15 amp fuse, mine was a 10 amp and I've replaced it with a 10 amp. And that the front outlet should have a 20 amp fuse, but in mine it's a 15 amp fuse.
Should I 'up' the fuses on these circuits to match the allowable loading stated in the manual, or leave alone and remember to use the front outlet for the heater in future ?
We've proven the manual wrong re fuse location, maybe the circuit loadings are inaccurate as well ?
I hope the above helps others.
regards to all
Allen
Jan 27, 2009
872
3,359
Leyland Lancs
since 2001
Allen,
Checks on my M/H confirm that F44 and F52 are also reversed, with a F44 15amp fuse, and a F52 20amp fitted. I just may fit two 15amp fuses !
Please send me a PM if you want a further chat.
blackie
75
N IRELAND
C/CLASS
10 YEARS
cig lighter not working
Allen,
does same apply to 2007 2.3 m/jet. blackie
43,319
49,401
Allen
fag lighter should be 10a...thats 120w @ 12v
secondary socket should be 15a...thats 180w @ 12v
and No..dont upgrade the fuses to a higher one...the wiring may not be up to the extra load.
blackie
75
N IRELAND
C/CLASS
10 YEARS
were is fag lighter fuse box blackie
walburga
Aug 20, 2007
574
637
Leyland
Frankia I7300 BD
I'm resurrecting this thread as it happened again...this time on my 55 reg Hobby 725.
Fag lighter fuse kaput, identified in fiat handbook as fuse F44...but it's not...it's Fuse F52, which in the handbook is the 'front outlet'.
And, as before, the fuse ratings in the book don't match the ones fitted in the fusebox.
Allen
Mar 26, 2022
Ace Novella 2002
Bumping this thread again because it was useful for me. Both cig sockets were dead in my RHD Fiat 2.8jtd. F44 was 15amp for the socket nearest the driver (it’s flip cover says “max 180w”) The other socket next to the ash tray does not show a rating but it’s blown F52 fuse was 20amp. This is as shown in my handbook.
...Dave
