These Classified Forums are now archived, so you cannot add to or edit them. Our New Classified System can be Found Here
i am very interested in one please, just need to confirm what the hole spacing is, as it varies between years
I'm interested in one, what age van are they off, as I don't know if they are all the same.
Also wouldn't be able to collect till mid March when we return from France.
Ok, they may not fit mine then as mine 2001. I will see if I can find out if they would fit.Hi, These are from a 2015 vehicle. I am led to believe, they should fit a 2007 onwards.
No problem on pick up date, if you want one. I will keep it for you.
No problemOk, they may not fit mine then as mine 2001. I will see if I can find out if they would fit.
purely out of intrest how does the valve position effect it? not something i would have even thought aboutI've done some searching and found that the valve position changed, yours are between studs and mine are in line with a stud , so they won't fit mine which is a shame.
The original wheel trims are secured by the wheel bolts and have a cut-out for the valve, so they wouldn't fit and I don't know what else is different e.g. Offsetpurely out of intrest how does the valve position effect it? not something i would have even thought about
ahh thats the difference my wheel trims when i had the ducato were in the center onlyThe original wheel trims are secured by the wheel bolts and have a cut-out for the valve, so they wouldn't fit and I don't know what else is different e.g. Offset
