Fiat courtesy light (1 Viewer)
Frankie
131
29
Buckinghamshire
c class
since 2008
Hi all,
How do you get to the bulbs in the courtesy light on a fiat ducato 08.Tried pulling and prising with out luck ,any more force would crack the plastic cover,any one know proper way.:Smile:
43,323
49,427
cant remember for sure but the whole lens doesnt come off only the center bit.
very fine screwdriver in one end and gently prise it out.
could be thinking of another vehicle and its too damned cold to go and check so dont force it.
steles
240
61
Kent
Panel Van Conversion
If you follow instructions in fiat manual you will find it easy, unless your converter has added some special fittings. Can you post photo?
Steles
Frankie
Frankie
131
29
Buckinghamshire
c class
since 2008
Hi, I had checked in manual but couldnt find anything,just rechecked and found it,I was prising at right points , obviously not enough effort put into it.Will have another look tommorow. Thanks for that,
:thumb:
