fiat chassis/suspension noise
Discussion in 'Base Chassis Section' started by jimmob, Jun 24, 2012.
  1. jimmob
    jimmob Read Only Funster
    Aug 20, 2011
    6
    yorkshire
    Hello everyone, i hope this is posted in the right place! Having just returned from 2 weeks travelling down to Biarritz in France I was almost driven insane by the squeaking/groaning noise from the rear axle area of our motorhome. Its a 09 Ci Mizar garage. When driving over uneven roads, speed ramps etc its realy loud and really embarrassing until the suspension settles! I know very little about this sort of thing and am unsure where to grease/replace parts etc. Its got 2 springs and air suspension too?
    I would be really grateful if anyone knows what to do or get in touch if they have had similar problems. I did ask the dealer but he said that all Fiats do this !
  2. stagman
    stagman Deleted User
    WD40 sprayed around the hangers now and again should solve it other thing is if you got air suspension and it is pumped too high this can also cause it :thumb:
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    WD40 on the spring hangers and bush's is fine short term but it does dry out.
    a quality aerosol type 'rubber lube' grease from a motor factors will last longer.
    failing that, the spring hanger bolts may be seizing in the bush's and will need removing, cleaning and greasing
    could also be one or more of the spring leaf thin rubber separator pads has disappeared allowing the leafs to rub together....if it ever had them fitted, some do some dont.
    and the odd thing.....i've had two fiat bases and neither squeaked or grinded so it sounds like the dealer couldn't be bothered to do anything about it.
  4. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,374
    9,819
    I believe you have an AlKo chassis on that van so it is extremely important to have the axle serviced correctly. These are well known for seizing up if not greased very regularly and eventually snapping suspension. leading to huge bills
    many garages have no idea about the special way of doing this. basically the van needs jacking up at the rear with the wheels hanging down, then grease the axle tube until you see it appear at the hub bearing. failing to do this properly leaves the suspension bars inside the axle under pressure and un greased
  5. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    could be wrong but....
  6. TheBig1
    Nov 27, 2011
    7,374
    9,819
  7. jimmob
    Aug 20, 2011
    6
    yorkshire
    Thanks for all the suggestions guys. It sounds like a dealer solution as I have very little idea of of where /what to grease/uncease! If only I could find a dealer who was interested in taking a look. Its booked in at Geoff Cox in 2 weeks so i will ask them to take a look again. If I sound like I might know something about it it may push them into action! Does anyone know where you can get a maintenance schedule/details from Alko about what is to be done ..... or do they have recommended dealers/service centres who would be willing to take a look?
  8. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    easiest way to ascertain if it has an Aklo chassis is get down and have a look.
    an Alko chassis will be bare silver/grey metal....probably dull silver/grey
    a standard Fiat chassis will be painted white or possibly black and may be rusty in places.
    an Alko chassis does not have visible springs.
    a standard Fiat chassis has visible springs.
    Alko axle has one, or possibly two depending on how old, grease nipples on the ends of the axle tube and should be greased at least once a year with the body weight taken off the axle.
    failure to grease can lead to the torsion bars seizing or even snapping
  9. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,068
    DERBYSHIRE
    If its an alko chassis and I think it is it looks like this and has a plate somewhere like this
