Fiat base vehicle option - self levelling suspension
Discussion in 'Motorhome Chat' started by dicksob, Sep 16, 2016.
  1. dicksob
    dicksob Funster
    Nov 17, 2013
    38
    41
    Edinburgh United Kingdom
    looking at speccing up our new base van for conversion. In the Fiat catalogue there is an option for self levelling rear suspension, cost £1500. Does anyone have any experience of this particular system ( as opposed to other systems) or if it is bought in kit? Looks attractive as it can be raised/lowered when parked.
    Bill
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,126
    17,793
    YO11 2BD
    Depends what you mean by self levelling.
    Load levelling or onsite auto levelling ?
    • Like it Like it x 1
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,787
    10,205
    As I understandit, the upgrade is just airbags and a compressor. The bags are linked to give side to side leveling. Same system as costs £400 fit it yourself or £500 fitted
  4. dicksob
    dicksob Funster
    Nov 17, 2013
    38
    41
    That's what I wondered, just the same Dunlop system them?
  5. pappajohn
    Aug 26, 2007
    30,126
    17,793
    YO11 2BD
    I would have thought, as its on the Fiat website, it would be a fore and aft levelling system for commercial vans to counteract uneven load pushing the rear end down.
    Volvo have a factory option on their V70 estate cars for load leveling .
  6. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,964
    12,253
    Plympton, Devon
    It's more than just self-levelling, you can raise and lower the rear end. Scroll down on this page for a description. http://www.fiatprofessional.co.uk/Models/Ducato_Goods_Transport/Load_capacity
    If it's not too expensive it would be a useful extra, good for rough ground and getting onto some ferries - but very much down to the design of the MH to make the most of it. Best on vehicles with a long rear overhang I think.
    Might be useful for pitching on a slope but only if it holds position when the engine is turned off, which hopefully it does. :)
  7. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,605
    7,885
    Looks to be rear air bags with a compressor.... Not much for all that money..
    I have done the same for £269 off ebay and use my foot pump (y)
    "Self-Levelling Rear Air Suspension
    The Fiat Ducato's optional self-levelling rear suspension ensures constant vehicle attitude and exceptional ride comfort under all load conditions. The system allows the rear load threshold to be reduced by up to 70 mm to facilitate loadspace access, or raising of the rear of the vehicle to improve both ramp angle and ground clearance.
    The load threshold level is lower than that of the conventional suspension system, and may be lowered still further via dashboard mounted switches. A choice of 11 threshold heights are available, 5 above and 5 below a central, default setting. Once adjusted, the height remains set up to a vehicle speed of 9 mph, whereupon the system automatically reverts to the default, driving height setting. For safety reasons, vehicle attitude may be adjusted only with the vehicle at a standstill, whilst the switches remain active with the engine off."
  8. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,429
    5,672
    Guisborough
    VB suspension have just developed "active dampers" to go with their air suspension, one of the features is a "lockout mode" to give stability once the 4 channel air has done the levelling, this might be for the IVECO chassis initially but I am sure it will trickle down. My understanding is that it was developed in conjunction with Morelo so they have the sole rights to fit it OE for one year.
    Martin
  9. dicksob
    dicksob Funster
    Nov 17, 2013
    38
    41
    Tonka, is your reading that "whilst switches remain active with the engine off" that this would allow, as DBK suggests, an element of levelling on an uneven pitch.
    The van will be an 6.36m plated at 4.2t with 2 electric bikes on back. Looking for improved road comfort and if possible a bit of help on pitching.
    Thanks for your help.
    Bill
  10. sallylillian
    sallylillian Funster Life Member
    Oct 29, 2011
    994
    602
    Falmouth, Cornwall
    That's interesting Martin, where did you get the information?
  11. funflair
    Dec 11, 2013
    5,429
    5,672
    Guisborough
  12. sallylillian
    Oct 29, 2011
    994
    602
    Falmouth, Cornwall
    That's very interesting I had active air on my RV and it was streets ahead of the VB I have on the Flair. I will be following this through, I will also like to understand how they manage the huge air requirements. I had air brakes on the rv and there were 5 tanks to manage the overall requirements. However you could swerve the 20 tons at speed like it was a mini!
    Thanks for the heads up.
    Michael
  13. sallylillian
    Oct 29, 2011
    994
    602
    Falmouth, Cornwall
    Martin here is a good Youtube on it.
  14. funflair
    Dec 11, 2013
    5,429
    5,672
    Guisborough
    When did you last drive your Flair like that Michael.
    Martin
  15. sallylillian
    Oct 29, 2011
    994
    602
    Falmouth, Cornwall
    Ha Ha
    They use the same manoeuvres in HWH (Yankee) active air presentation. However as you would guess it takes some balls to drive ones own like it!
    Michael
  16. funflair
    Dec 11, 2013
    5,429
    5,672
    Guisborough
    And some good anti-slip matting.
    Martin
