Fiat Autotrail - Dirty Step Problem (1 Viewer)
Nigel&Debbie
322
212
Full Timer
Autotrail Dakota
since Jan 2013
Hi,
I am the owner of a nice new shinny Fiat Autotrail Dakota, except for the Thule automatic step to the habitation area. This seems to act a magnet to all the crap that is thrown up by the road wheels:Sad:
Does anybody else suffer the same way and more importantly has anyone found a solution? i.e. will the extortionately priced Fiat front wheel mud flaps resolve the problem?
Nigel
May 23, 2008
2,480
3,481
Near Durham City
Carthago
Since 1984
I've had the same problem for many years on various vans. I found fitting rear mudflaps did help to reduce the dirt gathering on the step but didn't stop it.
I have now fitted a second rubber strip between the step and the rear wheel, this has almost stopped the problem. I am of the opinion that nothing can stop the air circulating the spray round these steps.
If you manage to cure the problem completely please let everyone know.
Southampton
522
318
Hampshire
Since 2009
I have the same problem on my Autotrail Comanche and I have front mud flaps. Don't know the answer and suspect we just have to live with it. My only concern is that to much crap and debris gets in the joints and affects the operation of it. Time will tell.
Xabia
1,186
821
Rural Nottinghamshire and Spain
Since 1996
To protect the hinge section of the step I have used some plastic damp proofing strip which is attached as a kind of reverse mud flap. It has been in place now for a couple of years and there has been no ingress of dirt into the mechanism which works fine.
Previously I had experienced problems with grit getting into the hinges and stopping the step from working properly.
Mike
Jan 11, 2010
2,743
9,476
Chester
Auto-trail
Well that`s our 13th year & still loving it.
dirty step
Hi we have an autotrail Arapaho and suffer the same problem from the rear wheels throwing all the road crap on the step, also look out for the wiring, there is a connection close to the step.
I cut a waterproof board to fit the profile of the side skirt to provide a solid wall between step and road wheels.
A dreadful design fault by Autotrail which they have never done anything about grrrr.
golly
2,001
69,106
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Same problem on my auto-sleeper Surrey, went get into van a couple of weeks after last outing and step not deploying. I had read of this problem so a good brushing of the joints and a liberal spray of silicone spray and eventually started working.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
Fit my mud flaps and also keep the van clean:thumb:
http://www.johnscross.co.uk/products/fiat-ducato-front-mud-flaps-x250.html
Fiamma do a cheaper one but we are out of stock
http://www.johnscross.co.uk/fiamma-front-motorhome-mud-flaps.html
Peter
I just have :thumb:.
Unfortunately, on the Auto-Trail Comanche it is the rear wheels that throw most of the crud onto the step.
See my thread "Case for the Defence" to for my reason for fitting front flaps ::bigsmile:
