colmorangie
Thanks in advance as always
Picked this van up a month ago and drove it home 250 miles no problems, checked over some areas ready for our first outing and discovered checked the pressure in the air suspension on the rear and found it to have 7psi in it the instructions said 7 psi minimum if it was being laid up and a maximum of 90 psi.
So I set it at 70 PSI ??? and left loaded up for a few days, after a couple of miles on roughish roads it appeared to judder and all the lights flashed on the dash board for seconds !!!
Carried on and got to the motorway no bother coming of the other end and driving through the Yorkshire dales this happened again a couple of times for longer periods (1 and 2 seconds not split seconds as the first time).
It sort of felt like the hand brake was being momentarily applied !!! or a bump had been massively exaggerated.
After speaking to someone on site I reset the rear suspension to 30 psi and could not make it happen again??
Could this be a case of the rear suspension being too hard and momentarily operating the safety cut off when going over bumps ????
